1 Reply Latest reply on Jun 18, 2008 9:23 AM by Oliver Goldman
    AIR SDK 1.1
    tcorbet
      After several hours of trying to synchronize my Flex SDK 3 environment with my new Air SDK 1.1 environment, I am able to get a clean compile, install and test -- basically still following the original "Getting Started" tutorial. When testing with adl, the window background fails to honor the 85% opacity setting that it has always had -- it's opaque. When the application comes up running under the AIR runtime -- same behavior.
      I see that some of the changes in 1.1 have something to do with the handling of 'native window transparency', but I did not see any FAQ or Release Note item stating that the external controls through either the api or the xml configuration file require new/different settings. Is there a document somewhere describing what the new settings are for achieving transparent windows?
