0 Replies Latest reply on Aug 10, 2009 11:40 AM by Darrell Loverin
    [svn:fx-trunk] 9206: Merge 3.4 changes 9109, 8949.
    Darrell Loverin Level 4
      Revision: 9206
      Author:   dloverin@adobe.com
      Date:     2009-08-10 11:39:33 -0700 (Mon, 10 Aug 2009)
      Log Message:
      Also fixed a bug in the generated code for IFlexModuleFactory.allowInsecureDomain() and cleanup up SystemManager by removing unused variables rslSizes and lastSystemManager.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-16050, SDK-22556
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-16050
          http://bugs.adobe.com/jira/browse/SDK-22556
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IFlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/RSLEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/Preloader.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcPreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
