0 Replies Latest reply on Aug 10, 2009 1:57 PM by jmurphy67
    [svn:fx-3.x] 9208:   Fix SDK-22318 by checking for an xsi: type attribute that specifies a concrete type before creating the shell to hold decoded element content .
    jmurphy67 Level 1
      Revision: 9208
      Author:   jimurphy@adobe.com
      Date:     2009-08-10 13:57:29 -0700 (Mon, 10 Aug 2009)
      Log Message:
        Fix SDK-22318 by checking for an xsi:type attribute that specifies a concrete type before creating the shell to hold decoded element content.
        Work around SDK-22327 by looking for enumerated values on generated strongly typed objects using the camel case version of the type name. A longer term solution would be to establish an interface to query the simple value from a strongly typed representation.
        QE notes: Thanks for running the cyclones!
        Doc notes: No
        Reviewer: Gaurav, Jody
        Tests run: Checkintests, QE ran cyclones for mxunit and WS tests.
        Is noteworthy for integration: Yes, this should be in 3.4.
        Bugs:
        SDK-22318 - deserialization process in ActionScript doesn't map to the correct response object
        SDK-22327 - returned SOAP enum doesn't get set to the actual value and is instead set to null
        r9131 | pfarland@adobe.com | 2009-08-05 22:49:16 -0400 (Wed, 05 Aug 2009) | 13 lines
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22318
          http://bugs.adobe.com/jira/browse/SDK-22327
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/rpc/src/mx/rpc/xml/XMLDecoder.as
      Property Changed:
