0 Replies Latest reply on Aug 10, 2009 2:19 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 9209: Fix bug http://bugs.adobe.com/jira/browse/SDK-22457 [ Gumbo_Priority] Layout bounds for FXG items are incorrect
    Evtim Georgiev (Adobe) Level 2
      Revision: 9209
      Author:   egeorgie@adobe.com
      Date:     2009-08-10 14:19:44 -0700 (Mon, 10 Aug 2009)
      Log Message:
      Fix bug http://bugs.adobe.com/jira/browse/SDK-22457 Layout bounds for FXG items are incorrect
      Fix:
      1. Add resizeMode property with default of 'scale' to SpriteVisualElement
      2. Switch the Graphic class default for the resizeMode property to 'scale'
      3. Beef up the transformation and sizing logic of the SpriteVisualElement.as
      4. Minor clean-up and fixes for UIComponent and UIMovieClip transformations
      QE notes: None
      Doc notes: None
      Bugs: SDK-22457
      Reviewer: Ryan
      Tests run: checkintests, spark/primitives/graphic, graphics, graphicTags
      Is noteworthy for integration: Yes, bug came from Thermo.
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Graphic.as
