15 Replies Latest reply on Aug 11, 2009 11:56 AM by jimmyoneshot
    Exchanging items between tilelists upon button click
    jimmyoneshot Level 1
      I have an app that allows users to exchange items between two tilelists and then save the changes they've made or reset any changes.
      What I want now however is for the users to be able to click the "Add selected link" and "Remove selected link" buttons and whatever item they have currently selected in that tilelist will be moved to the other tilelist. For example if a user clicks on an item in the left hand tilelist and then clicks the "Add selected link" button whilst the item is still selected that item will then be switched into the right hand tilelist. I'm not sure if this is possible without dragging each item though.
      Basically I want to advance the app so it contains this functionality aswell as drag and drop. The reason for all this is that my app will be installed on a system and some versions of this system will be operated by a tv like remote control so obviously dragging and dropping would be tricky without a mouse so this is just to offer an alternative.
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initprofile1NewsAndSportSO();"
      <mx:Script>
      <![CDATA[
      import
      mx.collections.*;
      import
      flash.net.SharedObject;
      public var
      profile1NewsAndSportSO:SharedObject;
      private var profile1NewsAndSportaddLinksFullAC:ArrayCollection = new
      ArrayCollection([
      {link:
      "www.bbcnews.com", label:"BBC News", icon:"image7", largeImage:"assets/images/bbcnews_small.png", title:"BBC News", description:"BBC News description will go here"
      {link:
      "www.itv.com/", label:"ITV", icon:"image5", largeImage:"assets/images/itv_small.png", title:"ITV", description:"ITV Description will go here"
      {link:
      "www.skynews.com", label:"Sky News", icon:"image10", largeImage:"assets/images/skynews_small.png", title:"Sky News", description:"Sky News Description will go here"
      private var profile1NewsAndSportaddLinksAC:ArrayCollection = new
      ArrayCollection([
      {link:
      {link:
      {link:
      private function profile1NewsAndSportReset():void
      resetprofile1NewsAndSportAC();
      profile1NewsAndSportAddLinksTilelist.dataProvider
      = profile1NewsAndSportaddLinksAC;
      profile1NewsAndSportLinkChoice.dataProvider =
      new
      ArrayCollection([]);
      private function resetprofile1NewsAndSportAC():void
      profile1NewsAndSportaddLinksAC.removeAll();
      for each(var obj:Object in
      profile1NewsAndSportaddLinksFullAC){
      profile1NewsAndSportaddLinksAC.addItem(obj);
      private function initprofile1NewsAndSportSO():void
      profile1NewsAndSportSO = SharedObject.getLocal(
      "profile1NewsAndSport"
      if
      (profile1NewsAndSportSO.size > 0){
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportaddList){
      if(profile1NewsAndSportSO.data.profile1NewsAndSportaddList != "empty"
      var profile1NewsAndSportaddList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportaddList.split(","
      var profile1NewsAndSporttempAC1:ArrayCollection = new
      ArrayCollection();
      for each(var str:String in
      for each(var obj1:Object in
      profile1NewsAndSportaddLinksAC){
      if
      (str == obj1.label){
      profile1NewsAndSporttempAC1.addItem(obj1);
      continue
      if
      (profile1NewsAndSporttempAC1.length > 0){
      profile1NewsAndSportAddLinksTilelist.dataProvider = profile1NewsAndSporttempAC1;
      if
      (profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList){
      var profile1NewsAndSportchoiceList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList.split(","
      var profile1NewsAndSporttempAC2:ArrayCollection = new
      ArrayCollection();
      for each(var str2:String in
      for each(var obj2:Object in
      if
      (str2 == obj2.label){
      profile1NewsAndSporttempAC2.addItem(obj2);
      continue
      if
      (profile1NewsAndSporttempAC2.length > 0){
      profile1NewsAndSportLinkChoice.dataProvider = profile1NewsAndSporttempAC2;
      else
      profile1NewsAndSportReset();
      private function saveprofile1NewsAndSport(event:MouseEvent):void
      var profile1NewsAndSportaddList:String = ""
      if
      (profile1NewsAndSportAddLinksTilelist.dataProvider){
      if
      (ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).length > 0){
      profile1NewsAndSportaddList += obj1.label +
      else
      profile1NewsAndSportaddList =
      "empty"
      profile1NewsAndSportSO.data.profile1NewsAndSportaddList = profile1NewsAndSportaddList;
      var profile1NewsAndSportchoiceList:String = ""
      profile1NewsAndSportLinkChoice.dataProvider){
      profile1NewsAndSportchoiceList += obj2.label +
      profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList = profile1NewsAndSportchoiceList;
      profile1NewsAndSportSO.flush();
      </mx:Script>
      <mx:Button click="profile1NewsAndSportReset()" id="reset
      label="
      Reset" y="5" height="25" x="5"
      <mx:TileList id="profile1NewsAndSportLinkChoice" fontWeight="bold
      dragEnabled="
      true" dragMoveEnabled="true" dropEnabled="true" height="129
      width="
      650" top="5" left="521" columnCount="5" rowHeight="145
      columnWidth="
      125" backgroundColor="#000000" color="#FFFFFF"
      <mx:TileList id="profile1NewsAndSportAddLinksTilelist" fontWeight="bold
      dragEnabled="
      width="
      385" top="5" left="128" columnCount="3" rowHeight="145" columnWidth="125
      backgroundColor="
      <mx:Button click="saveprofile1NewsAndSport(event)" id="save" label="Save Changes
      x="
      5" y="38" width="113" height="25.5"
      <mx:Button x="269" y="142" label="Add Selected Link" id="profile1NewsAndSportAddLinkButton"
      <mx:Button x="774" y="142" label="Remove Selected Link" id="profile1NewsAndSportRemoveLinkButton"
      </mx:Application>
        • 1. Re: Exchanging items between tilelists upon button click
          Gregory Lafrance Level 6
          Just do this:
          private function myAddButtonClickHandler():void{
              for each(var a:uint in list1.selectedindices){
                  if(!ArrayCollection(list2.dataProvider).contains(ArrayCollection(list1.dataProvider).getI temAt(a))){
                      ArrayCollection(list2.dataProvider).addItem(ArrayCollection(list1.dataProvider).getItemAt (a));
          similar for remove.
          If this post answered your question or helped, please mark it as such.
          • 2. Re: Exchanging items between tilelists upon button click
            Ok I've added in the names of my 2 tilelists into the script (in place of list 1 and list 2) and added the add button click function to the click of the add button however now whenever I run it and select an item in the tilelist and click the add button I get the error "#1009: Cannot access a property or method of a null object reference" pointing to the line -
            if(!ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).contains(ArrayCollection(pr ofile1NewsAndSportAddLinksTilelist.dataProvider).getItemAt(a))){
            I've noticed however if I drag the items around a bit and THEN click the add button with an item selected in the left hand tilelist it works but it creates a copy of the item rather than moving the item itself. It just seems it doesn't work when the app is in it's default state for some reason.
            Is it possible to set it so that clicking the add button will move the whole item from tilelist to tilelist rather than creating a copy and setting it so that it'll work as soon as the interface starts i.e with all items in their default positions?
            Sorry I'm clueless
            Here it is now:-
            <mx:Application
            <mx:Script>
            <![CDATA[
            private function profile1NewsAndSportAddButtonClickHandler():void
            profile1NewsAndSportAddLinksTilelist.selectedIndices){
            if
            ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).addItem(ArrayCollection(profi le1NewsAndSportAddLinksTilelist.dataProvider) .getItemAt(a));
            </mx:Script>
            <mx:Script>
            <![CDATA[
            import
            mx.collections.*;
            import
            public var
            ArrayCollection([
            {link:
            {link:
            {link:
            ArrayCollection([
            {link:
            {link:
            {link:
            new
            if
            if
            ArrayCollection();
            if
            continue
            if
            if
            ArrayCollection();
            if
            continue
            if
            else
            if
            if
            else
            "empty"
            </mx:Script>
            label="
            dragEnabled="
            width="
            650" top="10" left="519" columnCount="5" rowHeight="145
            columnWidth="
            dragEnabled="
            width="
            385" top="10" left="126" columnCount="3" rowHeight="145" columnWidth="125
            backgroundColor="
            x="
            <mx:Button x="126" y="147" label="Add" id="profile1NewsAndSportAddSelectedLinkButton" click="profile1NewsAndSportAddButtonClickHandler()"
            <mx:Button x="519" y="147" label="Remove" id="profile1NewsAndSportRemoveSelectedLinkButton"
            </mx:Application>
            • 3. Re: Exchanging items between tilelists upon button click
              You posted code is all messed up and when I copy it won't compile. I've fixed it in the past but its getting too big for me to spend the time to fix it, and anyway\ I've been meaning to ask you change how you post it for a while.
              When you post your code you need to click the >> to the right of the smily face in the toolbar here, and select Syntax Highlighting - Java.
              After that you will need to click in the box that is added and post your code.
              I usually copy from Flex Builder, paste to a test editor, then copy from there and paste into the box I mentioned above.
              • 4. Re: Exchanging items between tilelists upon button click
                Whoops, so sorry about that, I never realised at all
                That is a very useful addition though as I've noticed code is usually messed up when it gets pasted into here. I've pasted it into notepad and now into the box below as you say. Here it is:-
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initprofile1NewsAndSportSO();">
                  <mx:Script>
                   <![CDATA[
                   private function profile1NewsAndSportAddButtonClickHandler():void{
                    for each(var a:uint in profile1NewsAndSportAddLinksTilelist.selectedIndices){
                        if(!ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).contains(ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).getItemAt(a))){
                            ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).addItem(ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).getItemAt(a));
                  </mx:Script>
                  <mx:Script>
                    <![CDATA[
                      import mx.collections.*;
                      import flash.net.SharedObject;
                      public var profile1NewsAndSportSO:SharedObject;
                      private var profile1NewsAndSportaddLinksFullAC:ArrayCollection = new ArrayCollection([
                        {link: "www.bbcnews.com", label:"BBC News",  icon:"image7", largeImage:"assets/images/bbcnews_small.png", title:"BBC News", description:"BBC News description will go here"},
                        {link: "www.itv.com/", label:"ITV",  icon:"image5", largeImage:"assets/images/itv_small.png", title:"ITV", description:"ITV Description will go here"},
                        {link: "www.skynews.com", label:"Sky News", icon:"image10", largeImage:"assets/images/skynews_small.png", title:"Sky News", description:"Sky News Description will go here"}
                      private var profile1NewsAndSportaddLinksAC:ArrayCollection = new ArrayCollection([
                        {link: "www.bbcnews.com", label:"BBC News"},
                        {link: "www.itv.com/", label:"ITV"},
                        {link: "www.skynews.com", label:"Sky News"}
                      private function profile1NewsAndSportReset():void{
                        profile1NewsAndSportLinkChoice.dataProvider = new ArrayCollection([]);
                      private function resetprofile1NewsAndSportAC():void{
                        for each(var obj:Object in profile1NewsAndSportaddLinksFullAC){
                      private function initprofile1NewsAndSportSO():void{
                        profile1NewsAndSportSO = SharedObject.getLocal("profile1NewsAndSport");
                        if(profile1NewsAndSportSO.size > 0){
                          if(profile1NewsAndSportSO.data.profile1NewsAndSportaddList){
                            if(profile1NewsAndSportSO.data.profile1NewsAndSportaddList != "empty"){
                              var profile1NewsAndSportaddList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportaddList.split(",");
                              var profile1NewsAndSporttempAC1:ArrayCollection = new ArrayCollection();
                              for each(var str:String in profile1NewsAndSportaddList){
                                for each(var obj1:Object in profile1NewsAndSportaddLinksAC){
                                  if(str == obj1.label){
                                    continue;
                              if(profile1NewsAndSporttempAC1.length > 0){
                          if(profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList){
                            var profile1NewsAndSportchoiceList:Array = profile1NewsAndSportSO.data.profile1NewsAndSportchoiceList.split(",");
                            var profile1NewsAndSporttempAC2:ArrayCollection = new ArrayCollection();
                            for each(var str2:String in profile1NewsAndSportchoiceList){
                              for each(var obj2:Object in profile1NewsAndSportaddLinksAC){
                                if(str2 == obj2.label){
                                  continue;
                            if(profile1NewsAndSporttempAC2.length > 0){
                        }else{
                      private function saveprofile1NewsAndSport(event:MouseEvent):void{
                        var profile1NewsAndSportaddList:String = "";
                        if(profile1NewsAndSportAddLinksTilelist.dataProvider){
                          if(ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).length > 0){
                              profile1NewsAndSportaddList += obj1.label + ",";
                          }else{
                            profile1NewsAndSportaddList = "empty";
                        var profile1NewsAndSportchoiceList:String = "";
                          profile1NewsAndSportchoiceList += obj2.label + ",";
                  </mx:Script>
                  <mx:Button click="profile1NewsAndSportReset()" id="reset"
                    label="Reset" y="5" height="25" x="5"/>
                  <mx:TileList id="profile1NewsAndSportLinkChoice" fontWeight="bold"
                    dragEnabled="true" dragMoveEnabled="true" dropEnabled="true" height="129"
                    width="650" top="10" left="519" columnCount="5" rowHeight="145"
                    columnWidth="125" backgroundColor="#000000" color="#FFFFFF"/>
                  <mx:TileList id="profile1NewsAndSportAddLinksTilelist" fontWeight="bold"
                    width="385" top="10" left="126" columnCount="3" rowHeight="145" columnWidth="125"
                  <mx:Button click="saveprofile1NewsAndSport(event)" id="save" label="Save Changes"
                    x="5" y="38" width="113" height="25.5"/>
                  <mx:Button x="126" y="147" label="Add" id="profile1NewsAndSportAddSelectedLinkButton" click="profile1NewsAndSportAddButtonClickHandler()"/>
                  <mx:Button x="519" y="147" label="Remove" id="profile1NewsAndSportRemoveSelectedLinkButton"/>
                </mx:Application>
                • 5. Re: Exchanging items between tilelists upon button click
                  Uncomment the one line currently commented out if you want to removed item added back to the TileList on the left.
                  If this post answers your question or helps, please mark it as such.
                    <mx:Script>
                     <![CDATA[
                          if(!ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).contains(ArrayCollection (profile1NewsAndSportAddLinksTilelist.dataProvider).getItemAt(a))){
                              ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).addItem(ArrayCollection(prof ile1NewsAndSportAddLinksTilelist.dataProvider).getItemAt(a));
                              ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).removeItemAt(a);
                     private function profile1NewsAndSportRemoveButtonClickHandler():void{
                      for each(var a:uint in profile1NewsAndSportLinkChoice.selectedIndices){
                        ArrayCollection(profile1NewsAndSportAddLinksTilelist.dataProvider).addItem(ArrayCollectio n(profile1NewsAndSportLinkChoice.dataProvider).getItemAt(a));
                        //ArrayCollection(profile1NewsAndSportLinkChoice.dataProvider).removeItemAt(a);
                    </mx:Script>
                    <mx:Script>
                      <![CDATA[
                                      continue;
                                    continue;
                          }else{
                            }else{
                    </mx:Script>
                      creationComplete="profile1NewsAndSportLinkChoice.selectedIndex=0"/>
                      creationComplete="profile1NewsAndSportAddLinksTilelist.selectedIndex=0"/>
                    <mx:Button x="519" y="147" label="Remove" id="profile1NewsAndSportRemoveSelectedLinkButton" click="profile1NewsAndSportRemoveButtonClickHandler()"/>
                  </mx:Application>
                  • 6. Re: Exchanging items between tilelists upon button click
                    It's strange. That works fine as long as I've either clicked the reset button first or moved an item from 1 tilelist to the other however if the app is in it's default state when it first starts up and all items are in the left hand tilelist and I click one and click the add button I get the "Error #1009: Cannot access a property or method of a null object reference" error.
                    Here's what I mean by in its default state when the error occurs:-
                    http://i223.photobucket.com/albums/dd147/jimmyoneshot/def.jpg
                    Sorry about this.
                    • 7. Re: Exchanging items between tilelists upon button click
                      Did you see I am doing this:
                      That ensures something is selected at startup.
                      • 8. Re: Exchanging items between tilelists upon button click
                        Yep I noticed that. That part works fine and an item is selected as soon as the app runs but what is happening is that as soon as I run the app and click the add button with an item selected in the left hand tilelist I get the "Error #1009: Cannot access a property or method of a null object reference" error.
                        This only happens in the default state like in the above screenshot i.e. all items are in their original positions in the left hand tilelist and the app is started up, an item is selected in the left hand list and the add button is clicked. This causes the error.
                        It's very strange indeed as I can't see nothing wrong with the code and the object is not 'null'
                        • 9. Re: Exchanging items between tilelists upon button click
                          Have you pasted the code to an AIR app? The code I provided works fine for me.
                          • 10. Re: Exchanging items between tilelists upon button click
                            Not yet. I was just testing it in a Flex app for now. So it runs ok in AIR you think? I'll give it a try.
                            • 11. Re: Exchanging items between tilelists upon button click
                              It works perfect in AIR. So sorry about that my mistake. Well done mate.
                              • 12. Re: Exchanging items between tilelists upon button click
                                Actually, it worked fine for me in a Flex app as well. But I'm glad it worked for you in AIR at least.
                                • 13. Re: Exchanging items between tilelists upon button click
                                  It actually seems I'm still getting the error.  It just didn't appear last time for some reason
                                  It seems that it only happens when either of the tilelists is fully populated and the other is empty. To describe exactly what I mean if I do the following:-
                                  - Start the application
                                  - Drag all items into the right hand tilelist
                                  - Click 'Save changes'
                                  - Close and reopen / refresh the app
                                  - Click any item in the right hand tilelist / leave the one that is currently selected as the selected item
                                  - Click the remove button
                                  Doing the above for me using the exact code you sent produces the error "Cannot access a property or method of a null object reference".
                                  The same happens for the add button if ALL items are in the left hand tilelist when the app starts. It's crazy
                                  • 14. Re: Exchanging items between tilelists upon button click
                                    This code should fix the problem. I tried to make it so after adding an item the selected index updates, but I was getting some strange results, so if that is a concern you may need to start a new post.
                                      <mx:Script>
                                       <![CDATA[
                                          if(profile1NewsAndSportLinkChoice.dataProvider != null){
                                          }else{
                                            profile1NewsAndSportLinkChoice.dataProvider.addItem(ArrayCollection(profile1NewsAndSportA ddLinksTilelist.dataProvider).getItemAt(a));
                                      </mx:Script>
                                      <mx:Script>
                                        <![CDATA[
                                           profile1NewsAndSportLinkChoice.dataProvider = new ArrayCollection();
                                           profile1NewsAndSportAddLinksTilelist.dataProvider = new ArrayCollection();
                                                        continue;
                                                      continue;
                                            }else{
                                              }else{
                                      </mx:Script>
                                    </mx:Application>
                                    • 15. Re: Exchanging items between tilelists upon button click
                                      That works great now. No errors at all.
                                      Sorry about that I should have posted a new topic with my last post in because I forgot that I'd already gave you a Correct Answer for this topic
                                      I acually prefer it without an index initially selected anyway so I've removed the creationComplete from both tilelists. No worries there.
                                      Thanks a lot
