0 Replies Latest reply on Aug 10, 2009 5:30 PM by Jason Szeto
    [svn:fx-trunk] 9214: Slider Spark Skin for Halo bug fix
    Jason Szeto Level 3
      Revision: 9214
      Author:   jszeto@adobe.com
      Date:     2009-08-10 17:29:45 -0700 (Mon, 10 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-20191 - Disabled Halo Sliders look bad when using Spark skins
      The track and highlight track in Halo Slider were not getting disabled. Usually the skin?\226?\128?\153s state is controlled by its component. But in this situation, we have multiple skins for each of the different parts of the Slider. The thumb part is a button, so the thumb skin has a component associated with it. But the track and highlight track are just added directly to the Slider?\226?\128?\153s displayList.
      I added support into Slider to enable/disable the track and highlight track. I also updated the SliderTrackSkin and SliderHighlightTrackSkin to change their state based on the enabled value.
      The Halo Slider won't look exactly like the Spark Slider because of the way that Halo and Spark disable their components. In Halo, each of the individual parts is alpha'ed, which means the track will bleed through the thumb.
      QE notes: Update disabled Slider tests
      Doc notes: None
      Bugs: SDK-20191
      Reviewer: Glenn
      Tests run: Halo Slider
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderTrackHighlightSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderTrackSkin.mxml
