0 Replies Latest reply on Aug 10, 2009 5:30 PM by Jason Szeto
    [svn:fx-trunk] 9215: Event Propagation bug fix
    Jason Szeto Level 3
      Revision: 9215
      Author:   jszeto@adobe.com
      Date:     2009-08-10 17:30:21 -0700 (Mon, 10 Aug 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-21044 - Spark Components should use event.preventDefault instead of event.stopPropagation
      Since keyboard are now cancellable, the Spark components should use event.preventDefault() / event.isDefaultPrevented()  instead of event.stopPropagation. I updated ButtonBar, RadioButton, and DropDownList to use preventDefault(). Also cleaned up Slider and Spinner to always assume the event is cancellable.
      QE notes: Add tests with these components inside of scrollable containers
      Doc notes: None
      Bugs: SDK-21044
      Reviewer: Hans
      Tests run: Slider, Spinner, RadioButton, ButtonBar, DropDownList
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownCont roller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Slider.as
