6 Replies Latest reply on Aug 11, 2009 8:12 PM by kglad
    cannot parse data from xml
    alexManuelSilva
      I am trying to obtain strings from a xml file:
      I tried the following:
      var url:URLRequest = new URLRequest("blog.xml");
      var xml:XML;
      var rss:URLLoader = new URLLoader();
      rss.load(url);
      rss.addEventListener(Event.COMPLETE, readRss);
      function readRss(e:Event):void{
             xml = XML(rss.data);
             txt_field.text=xml.entry[1].author.name;
      but had no results. TypeError: Error #1010:...
      I tried tracing xml and that worked fine.
      The xml structure seems to be too complex
      var blogList:XMLList = xml.children(); //returns a more simple xml structure but still no success in parsing parts of the xml such as "title" or "author".
      Any suggestions would be greatly appreciated.
        • 1. Re: cannot parse data from xml
          you have to use that namespace.
          • 2. Re: cannot parse data from xml
            var xml:XML;
            rss.load(url);
            var ns:Namespace=xml.namespace();
                   txt_field.text=xml..ns::name[0];
            • 3. Re: cannot parse data from xml
              alexManuelSilva Level 1
              Hi Kglad,
              thank you for helping me with this post and all the previous threads.
              for accessing entry[1].title, i tried:
              xml..ns::entry[0].title // but didn´t really work.
              I also tried to retrieve all the items under "entry" with:
                 var ns:Namespace=xmlData.namespace();
                 var MSGCounter:int = 1;
                 for each (var item:XML in xmlData..ns)
                  txt_field.appendText("Post "+MSGCounter++ +"\n")
                  txt_field.appendText("------------------------------------------------------------------- -----\n");
                  txt_field.appendText(item.entry.title.toString());
                  txt_field.appendText("\n");
                  txt_field.appendText(item.entry.content.toString());
                  txt_field.appendText("\n ");
                  txt_field.appendText(item.entry.author.name.toString());
                  txt_field.appendText("\n\n");
              but had no success.
              • 4. Re: cannot parse data from xml
                try:
                xml..ns::entry[0].ns::title;  // for entry[0] title
                xml..ns::entry[1].ns::title;  // for entry[1] title
                • 5. Re: cannot parse data from xml
                  Thanks, kglad.
                  I added:
                     var ln:int = 5;
                     for(var i:int; i < ln; i++) {
                      txt_field.appendText(xmlData..ns::entry[i].ns::title);
                      txt_field.appendText(xmlData..ns::entry[i].ns::content);
                  • 6. Re: cannot parse data from xml
                    you're welcome.
