4 Replies Latest reply on Aug 11, 2009 8:39 AM by PeakDigital
    Keep PHP-generated XML as XML?
    PeakDigital
      I am working on my first Tree component, and wrote PHP script that generates my XML hierarchy using attributes, in the format demonstrated at http://livedocs.adobe.com/flex/3/html/help.html?content=dpcontrols_8.html  (The mailbox example).
      The return from the PHP script is handled by the HTTPService's result handler. When I debug it, the event.result shows as an ArrayCollection instead of XML.
      If I try to cast it to XMLList like this: var listXML:XMLList=XMLList(event.result.data); the listXML variable contains a single node containing "[object Object]".
      Is there any way to preserve my E4X XML data for use in my Tree component, or am I going to have to write code to convert it back to XML?
      Thanks.
      Paul
        • 1. Re: Keep PHP-generated XML as XML?
          Gregory Lafrance Level 6
          Ensure your HTTPService resultFormat property is set to e4x.
          In the result handler, do this:
          var xmllist:XMLList = event.result..myNode as XMLList;
          xlc = new XMLListCollection(xmllist);
          where xlc is a global XMLListCollection variable, and myNode is the node in the XML that repeats.
          If this post answered your question or helped, please mark it as such.
          • 2. Re: Keep PHP-generated XML as XML?
            PeakDigital Level 1
            Greg,
            Thank you for your reply.
            I had missed the resultFormat=4x; however even after fixing that I am running into problems getting the XML into an XMLList using the syntax you suggested. No error occurs, but my XMLList variable shows as null.
            My structure is:
            <data>
                 <parentLocation id="1" LocationName="Building 1">
                      <location id="3" LocationName="Room A">
                           <location id="5" LocationName="Cube 1-b"></location>
                           <location id="6" LocationName="Cube 2-C"></location>
                      </location>
                     <location id="10" LocationName="Room B"></location>
                 </parentLocation>
                 <parentLocation  id="2" LocationName="Building 2">
                      ...etc
                   </parentLocation>
            </data>
            In the debugger, I entered several variations of the dot-syntax event result into the expression pane:
            event.result.data = <errors during evaluation>   No such variable: data
            event.result<data> = <errors during evaluation>    Syntax error in expression
            event.result as XMLList = <errors during evaluation>    Expression could not be fully resolved
            event.result["data"]\n = <errors during evaluation>    No such variable: data
            event.result.<data>\n = <errors during evaluation>    Syntax error in expression
            event.result..data = <errors during evaluation>    Syntax error in expression
            event.result.data.parentLocation = <errors during evaluation>    No such variable: data
            event.result..parentLocation = <errors during evaluation>   Syntax error in expression
            If I type just "event.result" in the expressions pane, it shows "event.result = (XML) <data>    "
            I'll keep hacking away at this as long as I can keep my eyes open, running out of ideas.
            • 3. Re: Keep PHP-generated XML as XML?
              Muzak Level 3
              Since event.result equals <data>etc..</data> you don't use event.result.data to access it, but just event.result.
              So to get a list of parentLocation  nodes, use event.result.parentLocation
              var data:XML = event.result as XML;
              var locs:XMLList = data.parentLocation;
              trace(locs.toXMLString());
              • 4. Re: Keep PHP-generated XML as XML?
                PeakDigital Level 1
                Thank you!  That works.
                This is the first time I have tried to use XML in this format. I didn't make the connection between the expression pane showing "event.result = (XML) <data>   " to needing to bypass the root node.
                No end of learning new things in Flex, I guess.
                Thank you both for your assistance.
                Paul
