1 Reply Latest reply on Aug 11, 2009 7:21 AM by pguerett
    Tool to convert a pdf to xsd
    Renilrising
      I want to convert a pdf form to xsd.Because i need an  xml schema for a particular pdf form.Can anyone suggest a good tool to do this..its urgent..
        • 1. Re: Tool to convert a pdf to xsd
          pguerett Level 6
          Open the PDF in Designer and under the File/Form Properties/Preview menu you can "Generate Preview Data". Now that you have a data structure you can open it with your favorite XML editor (I use XMLSpy). There is an option to create a schema from the data file in that product. I do believe that there are a number of free websites that do ths as well. I did a google search on "Convert XML file to schema" and got numerous hits.
          Paul
