1 Reply Latest reply on Aug 11, 2009 4:14 AM by sirk214
    How to load local videos dynamic in the flex app from specific folder?
    sirk214
      Hi guys,
      I have an application which is working with a lot of video-material. This application should only run offline, so it s an local application.
      My idea was, that you save this application in a folder, which contains:
      - Application.swf
      - assets-folder
      The videos are in the assets folder, and the sources to the different videos are parsed from an xml-file, which the user can load, while the application is running. The application is something like a framework, so it should be extendable with different xml-files.
      Therefore, the videos are not embed, if you export your swf-file.
      So, how can I tell the swf-file, that the video-destination starts in the folder, where the Application.swf is saved?
      At the moment, videos sources are saved in the xml like this: "../assets/videofile.swf" But after compiling, I have to put the asset-folder on my desktop, that the videos are found.
      Thanks for your help,
      K
