1 Reply Latest reply on Aug 12, 2009 5:49 AM by jim1234
    Deployed Flex application not using secure Coldfusion Channel
    jim1234 Level 1
      I have a flex application that is using the secure coldfusion channel in development, and it works fine.  I checked it through firebug and it's definitely calling the https URL for the flexgateway.  I am using the -services option in the compiler to use the services-config.xml.
      When I move the flex application to the production machine, for some reason it reverts to using the non secure channel with the http protocol.  I tried a clean project build, but it still happens.  Below I'm posting my services-config and remote-config files to see if anyone can figure out anything.  Thanks, Jim.
      remoting-config.xml:
      <adapters>
              <adapter-definition id="cf-object" class="coldfusion.flash.messaging.ColdFusionAdapter" default="true"/>
              <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter"/>
          </adapters>
          <default-channels>
              <channel ref="my-cfamf-secure"/>
          </default-channels>
          <destination id="ColdFusion">
              <channels>
              </channels>
              <properties>
                  <source>*</source>
                  <!-- define the resolution rules and access level of the cfc being invoked -->
                  <access>
                      <!-- Use the ColdFusion mappings to find CFCs, by default only CFC files under your webroot can be found. -->
                      <use-mappings>true</use-mappings>
                      <!-- allow "public and remote" or just "remote" methods to be invoked -->
                      <method-access-level>remote</method-access-level>
                  </access>
                  <property-case>
                      <!-- cfc property names -->
                      <force-cfc-lowercase>false</force-cfc-lowercase>
                      <!-- Query column names -->
                      <force-query-lowercase>false</force-query-lowercase>
                      <!-- struct keys -->
                      <force-struct-lowercase>false</force-struct-lowercase>
                  </property-case>
              </properties>
          </destination>
      services-config.xml:
      <channel-definition id="my-cfamf-secure" class="mx.messaging.channels.SecureAMFChannel">
                  <endpoint uri="https://{server.name}:{server.port}{context.root}/flex2gateway/cfamfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                  <properties>
                      <add-no-cache-headers>false</add-no-cache-headers>
                      <polling-enabled>false</polling-enabled>
                      <serialization>
                          <instantiate-types>false</instantiate-types>
                      </serialization>
                  </properties>
              </channel-definition>
