I may not have explained my situation well...
Re the index:
- The index most likely is NOT inaccurate in online format.
But plan to output in a number of formats, and Word/Adobe is often
used. That IS my problem 🙂 No, the bookmark stuff isn't going to
work. I can test it further, but I can see that it may be
problematic because index keywords in RH are linked to the page
properties, not directly to the text. See, if you have a longish
topic with keyword like page, print, output and they are page
properties...you will go to that topic when output. But, you may
NOT go to the specific reference if it is Word/Adobe hardcopy
(meaning, page, output, print may really show up as index key terms
a few paragraphs AFTER the heading in hardcopy, and the heading may
be a page or so before those realy keywords). The XE index fields
are placed behind the heading text when exported to Word...so hence
the Word index will generate the page number for THAT page. I now
hand move the XE fields after generation. It's an "anal retentive"
thing of mine; however, it does make a document more accurate in
print.
2. Re glossaries: nah. I was looking for the inverse 😉 I
don't want to maintain six separate glossaries if I can help it. I
was being techy enough to wonder if I could pick and choose the
glossary entries I wanted from a "master" glossary. I got "bit"
this week by maintaining 6 separate glossaries. Because there IS
cross-over between glossaries, I had to manually edit a specific
entry in 4 of my 6 glossaries. That sort of bites when pressed at
deadline LOL. I was hoping I could link glossaries such that I
could only update the master and then generate specific entries
into specific outputs without maintaining separate glossaries.
An interesting twist to applying RoboHelp in different
production environments here, perhaps. One of the reasons we do use
it is because the topic text is generated in clear text via HTLM.
Much more compatible with Subversion, which we're requried to use
for versioning and file-sharing. That I can't debate or
change!!
