0 Replies Latest reply on Aug 11, 2009 11:51 AM by EstherCatherine
    Numbering in notes
      The auto numbering feature in PowerPoint notes does not convert correctly when published in Presenter.  If you use an outline format for numbering, Presenter converts the small letters (a, b, c)  to arabic numerals (1, 2, 3).  If you start your auto numbering with a number other than 1, Presenter changes the number to 1.  For example, if you use two slides to express a numbered series of thoughts -- 1, 2, and 3 on one slide and 4, 5, and 6 on the next slide -- Presenter changes the numbering on the second slide to 1, 2, and 3 in the notes section, but not on the slide.
      The only work around I have found so far is to hard-code in the numbers rather than using PowerPoint's auto numbering feature.  Any chance this could be fixed in a future version of Presenter?  Thanks!
