2 Replies Latest reply on Aug 12, 2009 5:31 AM by cbrylla
    problems with hyperlinks in dynamic text
      I have a dynamic textbox on the 3rd level of a flash movie. The textbox has some hyperlinks for which I used this AS2 code as a test:
      textbox.html = true;
      textbox.htmlText = "<a href=' http://www.adobe.com' target='_blank'>Adobe</a>";
      When I test the scene it works well on all levels apart from the root level. When I test the whole movie, the link does not respond. On rollover the mouse converts into a text cursor, and I have to click several times, until randomly a hand comes up and the link opens. I don't understand why on all sublevels (in the movieclips), the link works perfectly (on rollover mouse becomes hand and click loads URL int browser), but not on the root level. Btw, I placed the movie with the textbox on top, so there is no layer above that in the root timeline. Please help!!!
        • 1. Re: problems with hyperlinks in dynamic text
          dalcde Level 1
          try you getURL:
          onClipEvent (enterFrame){
               this.text = "Adobe"
               getURL("www.adobe.com", "_blank")
          • 2. Re: problems with hyperlinks in dynamic text
            cbrylla Level 1
            Thanks for your response dalcde. However, in my dynamic textbox I have a list with more than 50 different items with different links, and using the HTML tag seems more convenient.
            I experimented a bit and found out what causes the problem:
            The parent movie clip of the movie clip with the textbox has a mirrored reflection attached to it, for which I use this code:
            import flash.display.*;//importing the bitmap class
            var bmd:BitmapData = new BitmapData(860, 330);//definition of a variable for the target bitmap and assigning values
            link_ref.attachBitmap(bmd, 1);//attaches target bitmap to movie clip (reflection)
            link_ref.setMask(link_mask);//sets mask over movie clip (reflection)
            this.onEnterFrame = function()
            When I switch that off, the link works fine when testing the movie. This is a bit weired cause when I test the scene with the reflection (2nd level after root) the link works fine. The problem only occurs when I test the movie (level 1). Anyways, switching off the reflection is obviously not an option as all the sites on my website have reflections. Is there a workaround to this? I was never aware that the bitmap class could interfere with hyperlinks.
