13 Replies Latest reply on Aug 14, 2009 9:34 PM by kglad
    set dynamic link
    itgate.ir
      hi
      i have a xml file :
      <gallary>
          <buldingIcon number="4" iconsize="20"/>
          <icon iconUrl="images/1.png" xpos="220" ypos="410"  pageAddress="www.google.com"></icon>
          <icon iconUrl="images/2.png" xpos="190" ypos="150"  pageAddress="www.yahoo.com"></icon>
          <icon iconUrl="images/3.png" xpos="450" ypos="300"  pageAddress="www.alexa.com"></icon>
          <icon iconUrl="images/4.png" xpos="700" ypos="490"  pageAddress="www.alexa.com"></icon>
      </gallary>
      and the action script code , than read the xml file then crate the empty movieclip for each icons , set the position this movieclip to x=xpos and y=ypos , and finally load the iconUrl to movieclip :
      var myXml:XML = new XML();
      myXml.ignoreWhite = true;
      myXml.load("config.xml");
      myXml.onLoad = function(success) {
          num=myXml.firstChild.childNodes[0].attributes.number;
          for (i=1; i<=num; i++) {
              loader = this.firstChild.childNodes[i].attributes.iconUrl;
              var targetMC:MovieClip = _root.createEmptyMovieClip("al"+i, 10+i);
              targetMC.loadMovie(loader);
              targetMC._x = this.firstChild.childNodes[i].attributes.xpos;
              targetMC._y = this.firstChild.childNodes[i].attributes.ypos;
              t=this.firstChild.childNodes[i].attributes.pageAddress;
              targetMC.onMouseDown=function(){
              getURL(t,"_blank");
      now i set the html link to each icons , that load in the movieclip.
      in the red line code , i want solve this problem but wrong .
      can you help me what can i do set the html address in pageAddress attribute in xml file to per icons ?
      besr regards
        • 1. Re: set dynamic link
          try:
          <gallary>
          </gallary>
                  targetMC.t=this.firstChild.childNodes[i].attributes.pageAddress;
                  getURL(this.t,"_blank");
          • 2. Re: set dynamic link
            itgate.ir Level 1
            thanks
            but not work
            • 3. Re: set dynamic link
              that code works but you probably don't want to use onMouseDown.  use:
              <gallary>
              </gallary>
                     targetMC.onRelease=function(){
              • 4. Re: set dynamic link
                itgate.ir Level 1
                i replace this code
                but not work yet
                • 5. Re: set dynamic link
                  are you testing in your browser?
                  • 6. Re: set dynamic link
                    itgate.ir Level 1
                    yes , i test in firefox and IE but not work .
                    • 7. Re: set dynamic link
                      fix your getURL() so it prepends http:// and what does adding the trace() functions below show after a few clicks:
                      trace(targetMC.t);
                      trace(this.t);
                             getURL("http://"+this.t,"_blank");
                      • 8. Re: set dynamic link
                        itgate.ir Level 1
                        not work
                        the second trace not running
                        output:
                        www.google.com
                        • 9. Re: set dynamic link
                              num = myXml.firstChild.childNodes.length;
                              for (i=1; i<num; i++) {
                                  trace(i+": "+loader)
                                  var parentMC:MovieClip = _root.createEmptyMovieClip("al"+i, 10+i);
                                  var targetMC:MovieClip = parentMC.createEmptyMovieClip("targetMC", 1);
                                  parentMC.t = this.firstChild.childNodes[i].attributes.pageAddress;
                                  parentMC.onRelease = function() {
                                      getURL("http://"+this.t, "_blank");
                          • 10. Re: set dynamic link
                            itgate.ir Level 1
                            thanks a lot
                            the problem is corrected
                            can you tell me , how occured this problem ? and why the parentMC crate a  targetMC ?
                            • 11. Re: set dynamic link
                              any movieclip that's a load target loses its mouse handlers.  you either have to create a child movieclip that's the load target (which is what i did) or wait until loading is complete to define mouse handlers.
                              • 12. Re: set dynamic link
                                itgate.ir Level 1
                                thanks for  yor helps
                                best regards .
                                • 13. Re: set dynamic link
                                  you're welcome.
