5 Replies Latest reply on Aug 19, 2009 2:18 PM by konsti22
    Adding a button and click handler with Actionscript?
    Handycam Level 1
      I have a pop-up window based on a Spark panel.  I want to add buttons to it with Actionscript.  I know how to add the button itself, label, etc, but can't find anything on adding the click event and handler.
      So far:
      timesUpAlert = com.TimesUpPanel(PopUpManager.createPopUp(this,com.TimesUpPanel,true));
      timesUpAlert.title = "TIME'S UP!";
      var testButton:Button = new Button();
      testButton.label = "FOO!";
      Where "buttonGroup" is an HGroup in my component.
      I need to add a click event and handler that then I listen more in the parent application.
        • 1. Re: Adding a button and click handler with Actionscript?
          Flex harUI Adobe Employee
          testButton.addEventListener(MouseEvent.CLICK, someHandler)
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Adding a button and click handler with Actionscript?
            Handycam Level 1
            Thank you, perfect.
            Is there a way I can easily create a simple closebutton like
            which doesn't work, without having to create a whole handler just to close
            the popup?
            • 3. Re: Adding a button and click handler with Actionscript?
              You can have your button execute this code:
              Although I do usually stay away from using "parent", it is a very simple technique.
              I hope that helps.
              • 4. Re: Adding a button and click handler with Actionscript?
                Peter deHaan Level 4
                Not sure how clean it is, but you could try an anonymous inline function:
                            private function init():void {
                                btn.addEventListener(MouseEvent.CLICK, function ():void {btn.label = new Date().toTimeString()});
                    <s:Button id="btn" label="Spark Button" initialize="init();" />
                • 5. Re: Adding a button and click handler with Actionscript?
                  i'm new to establishing errohandlers in actionscript, and have a question that may be similar to the original one in his thread.
                  i have a tabnavigator- and a HBox-body that i create in mxml and that i want to fil with panels and buttons at runtime via actionscript. This works fine so far.
                  Here the code i use in short:
                  <?xml version="1.0"?>
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                      <mx:Panel title="TabNavigator Demo" height="90%" width="90%"
                          paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10">
                          <mx:TabNavigator id="TN"  width="100%" height="100%">
                          <mx:HBox id="TNTabSel">
                        import mx.controls.Label;
                        import mx.containers.VBox;
                        import mx.controls.Button;
                        private var i:int;
                        private function init():void{
                     ->   createLinkHandler();
                        private function initTabs(TabCount:int):void{
                            for (i=0; i<TabCount; i++) {
                              var Box:VBox = new VBox();
                              Box.label ="Tab " + (1+i).toString();
                              var Lbl:Label = new Label()
                              Lbl.text ="Panel " + (1+i).toString();
                              var Buttn:Button = new Button();
                        ->   Buttn.id = i.toString();
                              Buttn.label ="choose Tab " + (1+i).toString();
                  ->   private function linkHandler(event:MouseEvent):void {
                  ->      TN.selectedIndex=(event.target.id);
                  ->   private function createLinkHandler():void {
                  ->     TNTabSel.addEventListener(MouseEvent.CLICK,linkHandler);
                  My Problem now is, that the buttons do nothing when i click on them, as they would do when i programm the buttons in mxml
                  , much like in this code:
                              <mx:Button label="Select Tab 1" click="TN.selectedIndex=0"/>
                              <mx:Button label="Select Tab 2" click="TN.selectedIndex=1"/>
                              <mx:Button label="Select Tab 3" click="TN.selectedIndex=2"/>
                  Can someone please help me?
                  Thanks alot.
                  i tried a slightly different approach and, viola, it works like i want.
                  I marked the new inserted Lines with "->".
                  Maybe someone has use for it.
                  Thanks again.
