7 Replies Latest reply on Aug 19, 2009 1:44 PM by manofspirit
    Tabbing is not working as expected, Please Help
    manofspirit Level 1
      Hello guys
      I am into a issue regarding Tabbing,
      I have a simple form with 2 TextFields and One Button
      Email    [tabIndex = 0]
      Password    [tabIndex = 1]
      [Button]     [tabIndex = 1]
      signInKeyboard(event:KeyboardEvent):void{
                  if(event.keyCode == 13 || event.keyCode == 32){ //enter and space
                      signIn();
                  }else if(event.keyCode == 9){    //tab
                      Email.setFocus();
      Now the problem is, When i run that code and press "Tab" over Button
      Focus goes to "Password" rather than "Email Text Field"
      please guide in this regard.
        • 1. Re: Tabbing is not working as expected, Please Help
          Jed Schneider Level 1
          tabIndex =0 ignores that field for indexing.
          Try this code (Flex 4) but replace withs:textinputs with mx:textinputs for 3.x and you should be set. In mxml you dont need to add an actionscript function to handle the tabIndex if you specify it. That is handled for you by the framework.
          <s:Application ...>
          <mx:Form>
          <s:TextInput tabIndex="1"/>
          <s:TextInput tabIndex="2"/>
          <s:Button/>
          </mx:Form>
          </s:Application>
          • 2. Re: Tabbing is not working as expected, Please Help
            manofspirit Level 1
            Hi Jed
            I tried this too but again, it doesnt work
            Here is my Code, Tab goes back to "Password" rather than "Email"
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundGradientAlphas="[1.0, 1.0]" backgroundGradientColors="[#FFFFFF, #FFFFFF]">
            <mx:Script>
                 <![CDATA[
                     private function loginKeyboard(event:KeyboardEvent):void{
                               login();
                               logEmail.setFocus();
                               event.stopPropagation();
            </mx:Script>
                      <mx:TextInput id="logEmail" tabIndex="1"/>
                      <mx:TextInput id="logPassword" displayAsPassword="true" tabIndex="2"/>
                      <mx:Button label="Login" keyDown="loginKeyboard(event)" click="loginHandler(event)" tabIndex="3" id="loginBtn"/>
            </mx:Application>
            • 3. Re: Tabbing is not working as expected, Please Help
              like i said, you don't need a function to handle the tabIndex if you speicfy it in flex markup. try this
              <mx:Script>
                   <![CDATA[
              </mx:Script>
                        <mx:Button label="Login" keyDown="loginKeyboard(event)" tabIndex="3" id="loginBtn"/>
              </mx:Application>
              • 4. Re: Tabbing is not working as expected, Please Help
                manofspirit Level 1
                I actually have two forms
                one for signin, and second for signup
                login form has indices from 1 to 3
                and signup have 4 to 8
                so in this case i want to programmatically set tabbing.
                • 5. use states, not two forms
                  use one form and change states. this should help you out.
                  http://livedocs.adobe.com/flex/3/html/help.html?content=using_states_2.html
                  • 6. Re: Tabbing is not working as expected, Please Help
                    Flex harUI Adobe Employee
                    You should have unique tabIndex for each field.  If more than one component has the same index you lose control over which one gets focus first.
                    If you want to override the FocusManager's decision, use KEY_FOCUS_CHANGE and preventDefault() instead of KEY_DOWN and stopPropagation
                    Alex Harui
                    Flex SDK Developer
                    Adobe Systems Inc.
                    Blog: http://blogs.adobe.com/aharui
                    • 7. Re: Tabbing is not working as expected, Please Help
                      manofspirit Level 1
                      Thanks to both friends
