2 Replies Latest reply: Jan 12, 2010 3:40 AM by Daniel Carraretto RSS
    Difficult in testing FMS 3.5 (player do not connect)
    Daniel Carraretto
      Hi All,
      I am trying the FMS 3.5. I´ve just install the Trial and downloaded the Flash Encoder.
      I want to stream a live audio 24/7 in to the internet using FMS 3.5 and in teh future i am planning to stream live videos and on-demmand videos. But 1st problems 1st...
      I installed and cretated a live aplication in to the server following a tutorial an adobe articles:
      http://www.adobe.com/devnet/flashmediaserver/articles/webcasting_fme.html
      All the the fases were good, installed the FMS, created the aplication, conected the encoder to FMS but when i tried to create the player using Dreamweaver CS3 (like to tutorial, in page 5) i got my connection and streaming problem.
      I create the HTML with the object, put all SWF files and Scripts (that dreamweaver created) and HTML files in to the web-server and in the same folder, but when i acess the address it did not open.
      And in the connection manager in admin interface it detects the connection. But do not stream, the HTML that Dreamweaver creteted was:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      function MM_CheckFlashVersion(reqVerStr,msg){
        with(navigator){
          var isIE  = (appVersion.indexOf("MSIE") != -1 && userAgent.indexOf("Opera") == -1);
          var isWin = (appVersion.toLowerCase().indexOf("win") != -1);
          if (!isIE || !isWin){
            var flashVer = -1;
            if (plugins && plugins.length > 0){
              var desc = plugins["Shockwave Flash"] ? plugins["Shockwave Flash"].description : "";
              desc = plugins["Shockwave Flash 2.0"] ? plugins["Shockwave Flash 2.0"].description : desc;
              if (desc == "") flashVer = -1;
              else{
                var descArr = desc.split(" ");
                var tempArrMajor = descArr[2].split(".");
                var verMajor = tempArrMajor[0];
                var tempArrMinor = (descArr[3] != "") ? descArr[3].split("r") : descArr[4].split("r");
                var verMinor = (tempArrMinor[1] > 0) ? tempArrMinor[1] : 0;
                flashVer =  parseFloat(verMajor + "." + verMinor);
            // WebTV has Flash Player 4 or lower -- too low for video
            else if (userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 4.0;
            var verArr = reqVerStr.split(",");
            var reqVer = parseFloat(verArr[0] + "." + verArr[2]);
            if (flashVer < reqVer){
              if (confirm(msg))
                window.location = "http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash";
      </script>
      <script src="Scripts/AC_RunActiveContent.js" type="text/javascript"></script>
      </head>
      <body onload="MM_CheckFlashVersion('6,0,79,0','Content on this page requires a newer version of Adobe Flash Player. Do you want to download it now?');">
      AC_FL_RunContent( 'codebase','http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,79,0','wid th','342','height','101','id','FLVPlayer','src','FLVPlayer_Streaming','flashvars','&MM_Com ponentVersion=1&serverName=www2.gazetaonline.com.br&skinName=Halo_Skin_3&appName=myliveapp /instance1&streamName=livestream&isLive=true&bufferTime=2&autoPlay=false&autoRewind=false' ,'quality','high','scale','noscale','name','FLVPlayer','salign','lt','pluginspage','www.ad obe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movie','FLVPlayer _Streaming' ); //end AC code
      </script><noscript><object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,79,0" width="342" height="101" id="FLVPlayer">
        <param name="movie" value="FLVPlayer_Streaming.swf" />
        <param name="salign" value="lt" />
        <param name="quality" value="high" />
        <param name="scale" value="noscale" />
        <param name="FlashVars" value="&MM_ComponentVersion=1&serverName=server_address&skinName=Halo_Skin_3&appName=myli veapp/instance1&streamName=livestream&isLive=true&bufferTime=2&autoPlay=false&autoRewind=f alse" />
        <embed src="FLVPlayer_Streaming.swf" flashvars="&MM_ComponentVersion=1&serverName=server_address&skinName=Halo_Skin_3&appName= myliveapp/instance1&streamName=livestream&isLive=true&bufferTime=2&autoPlay=false&autoRewi nd=false" quality="high" scale="noscale" width="342" height="101" name="FLVPlayer" salign="LT" type="application/x-shockwave-flash" pluginspage="www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash " />
      </object></noscript>
      </body>
      </html>
      Any one had a clue what i´ve done wrong ????
      OBS: I attached to this post, a printscreen of the encoder "encoding" the audio and all the configuration that i used in the flash encoder.
