4 Replies Latest reply on Aug 13, 2009 6:30 AM by Wade_Zimmerman
    Unwanted trapping
    jebediah3 Level 1
      Hi, I'm having some issues with Photoshop CS3/Illustrator CS3.
      In Illustrator, I have a CMYK psd file with a transparent background placed on top of a background that is coloured with a PMS colour. In Illustrator this looks fine however when I go to make a pdf (both high or low res), there is a dark line around my image, where it meets the background spot colour.
      It's as if one of the programs is adding trapping to my image - the background colour is overlapping the edge of the photo at about 1 pixel wide.
      How can I turn this trapping off? I can't for the life me figure out why it's appearing.
      Thanks in advance, Darren
      BTW I tried attaching a file but the browser couldn't seem to make it happen.
        • 1. Re: Unwanted trapping
          Wade_Zimmerman Level 6
          You attach a screen shot or image with the camera tool and attach a file with the attach file feature.
          Attaching a file soneone suggested that if it shows up as queued then try to attach it again?
          A screenshot would be helpful.
          • 2. Re: Unwanted trapping
            jebediah3 Level 1
            Thanks Wade. So this is a screen grab of what I'm seeing in my pdfs. There should be no dark outline around the pineapple and this dark outline does not show up when I look at the artwork in Illustrator.
            Cheers, Darren
            • 3. Re: Unwanted trapping
              RogerPaine Level 1
              it looks to me like your psd file has some transparent areas that are not fully transparent - have you checked that there is no redundant pixels in the trans area? I would also make a selection of your trans area (in ps), expand it one or two px and delete - see if that has any efect on your ai file.
              Alternatively you could mask the object in ai. I have done this: copy the image auto trace so that you get only an outline of the bit you want - ignore white - expand and paste the image behind - select all and make clipping mask. you can then adjust the mask to get a perfect fit.
              • 4. Re: Unwanted trapping
                I think in this case it might be better to simply mask it in AI as it
                does seem not to be a clean silhouette as you can easily see other
                pixel artifacts.
                I think a clean path in AI will give you the hard edge clean
                silhouette you are looking for.
                This is a pdf made from Illustrator with the clipping mask also mad in Illustrator.
                Of course if I had the original and not a screenshot things would look much better
                But you get the idea, You could go back to Photoshop an do some more careful erasing of the background.
                Here is the path I used to make the clipping it takes about 5-10 minutes
                And if you want a drop shadow that might be best in Illy as well
                some of the other guys like Scott and James and Hans could d this better but the level of skill and practice is always importat.
                Now if you want it a little softer on the edges I would then go back to Photoshop do a more detailed silhouette and give it a light feather in Photoshop.
