• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Help changing files
New Here ,
Aug 13, 2009 Aug 13, 2009
Hello, I' have made a project and I can publish it, but when I try to move one file to another directory I can't reproduce correctly the project.
Can anybody help me? I really need to move the files to other directories because I have to update it into a server.
TOPICS
Import export
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
musicsoft wrote:
...but when I try to move one file to another directory I can't reproduce correctly the project.
We need more information here. What file are you trying to move? Typically Captivate produces multiple files. They typically ALL need to be moved to the same place for things to work.
Please tell us exactly which files you are moving and why you are moving them.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
The project have a .flv file and when I produce the project. I have two swf files and the .flv file in the project's folder.
When I click in Captivate at Flash Video in the video's root I put the root of the server with the .flv (e.x. http://sdasdasd.com/Videos/untitled.flv)
After produce it, I have the two swf, one .flv file and one .html file. When I try to upload the two swf files and the html file to the server, I can't reproduce the video, probably because the .flv file is in other folder.
Can be possible move the files into differents folders?
I'm making this movements because this is the structure of the server.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
If all your videos are in the same place on the server, I'm thinking you would be reasonably safe using an absolute reference to the video. So instead of VideoName.FLV, you would insert the full URL: http://sdasdasd.com/Videos/untitled.flv
Have you tried that? If so, I have no answer for why it wouldn't be working other than to suggest a path and naming issue. For example, the server is UNIX or LINUX based and you called the video untitled.flv when in reality it is Untitled.FLV (note the case difference)
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Hello, I've tried to use an absolute reference to the video but it doesn't work.
The server is based on Windows 2003 Server are the name of the video is the same.
I don't know why it is happening....
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi again
Hmmm, Windows 2003 server. Seems I recall something about that. Have you tried other videos? Do they play? You might be surprised to discover they don't.
Take a look at the Technical Note linked below. See if that helps anything.
Click here to read
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Hi again,
I was reading the technical note and I can`t found  this optios, I'm using i.e 6 officaly, but i tried in others like firefox and chrome and nothing.
But it's rare because I can see other .swf but I don't understand why I can't reproduce the .flv file into the swf.
Votes
Translate
Translate
Report
Report
Explorer ,
Are you sure that there isn't a .js file that is produced, too when you generated your video? (for example a standard.js file?) If so, that needs to be in the same folder.
By the way, I use Windows 2003 Server for all my Captivate files and they display correctly.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
But if the .JS were missing, nothing would display. It wouldn't be limited to .FLV files.
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Yes I have the .js file but I don't know where I have to put the root of the server file...
I have saved the .js file into SCRIPT'S folder and I have modified the script refernce in the html wich is generated.
Votes
Translate
Translate
Report
Report
Resources
Help resources
