3 Replies Latest reply on Sep 28, 2009 3:48 PM by rmj134
    VideoPlayer complete event firing early
    RossRitchey Level 4
      I'm not sure why this is happening, but for some reason the complete event is firing about 5-10 seconds into my minutes long video.
      Here is the code for the VideoPage that loads the video and listens for the events. Does anything seem off to anyone?
      package com.applied.flex.pages
           import com.applied.flex.events.PageEvent;
           import flash.events.ProgressEvent;
           import spark.components.VideoPlayer;
           import spark.events.VideoEvent;
           public class VideoPage extends BasePage
                private var _video:VideoPlayer;
                private var _startTime:uint = 0;
                private var _endTime:uint;
                private var _cuePoints:Array;
                private var _displayedPoints:Array;
                private var resetting:Boolean = false;
                private var seekSafe:Boolean = true;
                public var readyToStart:Boolean = false;
                public function VideoPage(xml:XML,majorType:String,minorType:String,path:String)
                     super(xml,majorType,minorType,path);
                     _video = new VideoPlayer();
                     if(xml..Video[0].@StartTime != undefined)
                          _startTime = xml..Video[0].@StartTime;
                     if(xml..Video[0].@EndTime != undefined)
                          _endTime = xml..Video[0].@EndTime;
                     _cuePoints = new Array();
                     for each(var i:XML in _pageXML.Video.CuePoints.children())
                          _cuePoints.push(i.@OnTime);
                     _video.addEventListener(VideoEvent.READY,doVideoReady);
                     _video.source = path;
                     this.addChild(_video);
                private function doVideoReady(e:VideoEvent):void
                     _video.removeEventListener(VideoEvent.METADATA_RECEIVED,doVideoReady);
                     if(_pageXML..Video[0].@EndTime == undefined)
                          _endTime = _video.totalTime;
                     readyToStart = true;
                     this.dispatchEvent(new PageEvent(PageEvent.READY_TO_START,false,false,0,this));
                public override function startPage():void
                     addListeners();
                     _video.seek(_startTime);
                public override function resumePage():void
                     addListeners();
                     _video.play();
                public override function pausePage():void
                     removeListeners();
                     _video.pause();
                public override function stopPage():void
                     removeListeners();
                     var ar:Boolean = _video.autoRewind;
                     _video.autoRewind = true;
                     _video.stop();
                     _video.autoRewind = ar;
                public function seekPage(seekTo:Number):void
                     if(seekSafe)
                          removeListeners();
                          _video.pause();
                          _video.addEventListener(VideoEvent.PLAYHEAD_UPDATE,doSeekSafe);
                          _video.seek(seekTo);
                          seekSafe = false;
                private function doSeekSafe():void
                     _video.removeEventListener(VideoEvent.PLAYHEAD_UPDATE,doSeekSafe);
                     addListeners();
                     _video.dispatchEvent(new VideoEvent(VideoEvent.PLAYHEAD_UPDATE));
                     seekSafe = true;
                private function addListeners():void
                     _video.addEventListener(VideoEvent.COMPLETE,dispatchPageComplete);
                     _video.addEventListener(VideoEvent.PLAYHEAD_UPDATE,doVidProgress);
                private function removeListeners():void
                     _video.removeEventListener(VideoEvent.COMPLETE,dispatchPageComplete);
                     _video.removeEventListener(VideoEvent.PLAYHEAD_UPDATE,doVidProgress);
                private function doVidProgress(e:VideoEvent):void
                     var scrubObj:Object = new Object();
                     scrubObj.currentTime = (e.currentTarget as VideoPlayer).playheadTime;
                     scrubObj.totalTime = _endTime - _startTime;
                     trace("playheadTime | "+e.currentTarget.playheadTime);
                     trace("end time | "+_endTime);
                     dispatchUpdateScrubber(scrubObj);
                     checkForCuePoint(e);
                     if(_video.playheadTime >= _endTime)
                          dispatchPageComplete();
                private function checkForCuePoint(e:VideoEvent):void
                     if(_cuePoints.length > 0)
                          if( (e.currentTarget as VideoPlayer).playheadTime > _cuePoints[0].toString() && !resetting )
                               var item:Object = new Object();
                               item.point = _pageXML..CuePoints[_displayedPoints.length].toString()+"<br><br>";
                               dispatchUpdateScrubber(item);
                               _displayedPoints.push(_cuePoints.shift());
