14 Replies Latest reply on Aug 13, 2009 8:34 AM by the_wine_snob
    Creating Bullets in titles
    rtprtp Level 1
      Hi Friends,
      Does anyone know how to creat bullets in titles. I need to create a list of bulleted copy points and dissolve them one at a time onto the scene. So far I have used the Circle to and created them manually, but I am hoping there is a better way, maybe a font that has bullets.
      Thanks, Stan
        • 1. Re: Creating Bullets in titles
          the_wine_snob Level 9
          For Bullets, I use my word processor and Ctrl+c/Ctrl+v (Copy/Paste) to do this. Even if I am doing my Titles in Photoshop, I find this easier. One can also access the extended ASCII character set via Character Map, or the various Alt+ key combos on the numberpad. There are good Bullets there, and if one has Wingdings, and Webdings fonts, there are many more.
          Hunt h
          • 2. Re: Creating Bullets in titles
            rtprtp Level 1
            Hunt,
            I have yet to import from Word. How do you do that? Sounds like a great solution. Do you copy paste one bulleted line at a time in ordedr to have them seperated in order to build with a dissolve?
            Thanks, Stan
            • 3. Re: Creating Bullets in titles
              Stan,
              That is exactly how I do it. I have WordPerfect, or Word open and do the typing and font selection there. I do my Titles one line at a time, so I can apply different animations to them, as is needed. To get the text into Titler, I just Ctrl+c the selected text, and switch to Titler to Ctrl+v.
              One thing that I usually do, but that is not available in PrE, is to do my Titles as a Layered .PSD in Photoshop. In PrPro, I can Import>Sequence, and keep my Layers intact. In PrPro, each Layer comes in on a separate Video Track, one above the other. This keeps the alignment and leading correct, but each line is a discrete Clip and can be animated separately. PrE does not allow this, as it does not have Sequences (kind of like mini-Projects, in a Project).
              • 4. Re: Creating Bullets in titles
                rtprtp Level 1
                Thanks Hunt.
                One last question...Is there a grid I can bring up in the Titler to help with alignment? I couldn't find one.
                Stan
                • 5. Re: Creating Bullets in titles
                  Not really. I make them, as is necessary, in Photoshop. I'm usually doing them for things like PiP placement, though I have some straight ones with just the grid lines. I'll just Import these and place them on a Video Track above my main Video, but below the Title. In PrPro, I just click Show Video (believe that this is always ON in PrE), and can even turn the main Video's view OFF, if that helps me see the grid. When done, I either just remove that grid .PSD, or in PrPro, turn that Video Track OFF, before I Export, or I will have the grid in the final Video - something that I usually do not want.
                  • 6. Re: Creating Bullets in titles
                    rtprtp Level 1
                    Good idea Hunt, as always!
                    • 7. Re: Creating Bullets in titles
                      Here is an NTSC Wide Screen Grid in .PSD format w/ transparency. Hope that .PSD will attach.
                      [Edit] Looks like Adobe will not allow .PSD's to be attached. Will archive this file and try again.
                      Message was edited by: the_wine_snob Added [Edit]
                      • 8. Re: Creating Bullets in titles
                        Here is an NTSC Wide Screen Grid in .PSD format w/ transparency. Hope that .PSD's will attach.
                        • 9. Re: Creating Bullets in titles
                          rtprtp Level 1
                          not attached. my email is staylor at raskintaylor.com.
                          Thanks!!
                          • 10. Re: Creating Bullets in titles
                            Looks like Zipping the .PSD worked.
                            If you are in PAL-land, let me know and I can modify this for you. Also, because of the PAR (1.2), the vertical lines are not the neatest that I've seen.
                            Even though this is WS, 16:9, it will still work in 4:3 Projects. Just remember to remove it, before Export, as PrE doesn't allow for one to turn VT's OFF, I do not believe.
                            • 11. Re: Creating Bullets in titles
                              rtprtp Level 1
                              still didn't get the file.
                              working in NTSC
                              • 12. Re: Creating Bullets in titles
                                Go up to Post #7 and look at the bottom of the reply. You should see the attached file.
                                • 13. Re: Creating Bullets in titles
                                  rtprtp Level 1
                                  Got it. Thanks so much!!! This is gonna save me.
                                  • 14. Re: Creating Bullets in titles
                                    As mentioned earlier on, I create these with the "boxes" for PiP's too. PrE has some Presets, but PrPro does not - all is done by hand. The positioning "boxes" save me having to do a bunch of math, and saves a lot of typing in coordinates. I just drag to the appropriate "box."
                                    PS one thing that I found out years ago was that if I Exported out a .PSD from PS with the program's Grid (set in View), and then opened that .PSD in Painter, it brought in the Grid. I could then Save_As out of Painter with PS's Grid, and then set the Transparency back in PS. I discovered this, when the Grid that does not print out of PS, did in Painter - not what I wanted, but then the idea hit me to use that to my advantage. I just had to turn OFF the Grid View in PS, if I was going to Open in Painter.
