11 Replies Latest reply on Oct 31, 2009 2:52 PM by Harm Millaard
    Premiere Pro CS3 vs CS4
    hughie49
      I am currently editing using P.Pro CS3 along with CS3 ULTRA (not supported in CS4)  My question is can I update my P.Pro from CS3 to CS4 and still be able to use the CS3 ULTRA Program.
      Thank You
      Hugh Daly
      JHD Productions Ltd.
        • 1. Re: Premiere Pro CS3 vs CS4
          Bill Gehrke Adobe Community Professional & MVP
          I have not used Ultra so take this with a grain of salt.  But Ultra I believe is a stand-alone program.  Hopefully some Ultra users can give us some actual data.
          • 2. Re: Premiere Pro CS3 vs CS4
            Harm Millaard Level 7
            As long as there is one CS3 application installed on your system (Photoshop, Flash, Illustrator or any of the other key programs) you can use Ultra CS3.
            I have Flash CS3 installed, Ultra CS3 and the whole CS4 Master Collection. No problems with Ultra.
            • 3. Re: Premiere Pro CS3 vs CS4
              hughie49 Level 1
              Thank You, Thank You, Thank You....
              Hugh Daly
              JHD Productions
              Long Island NY
              • 4. Re: Premiere Pro CS3 vs CS4
                Just make sure one of the key CS3 applications is installed, because if you do not have one installed, Ultra will operate as a trial version and after 30 days will notify you that the trial period has expired and will close down. I know from personal experience. The only way to get it working as the full version again was to reinstall one of the key programs. I have chosen Flash because it is pretty small in footprint.
                BTW, I don't object to points for the correct answer. Makes the lunch will Bill come closer.
                • 5. Re: Premiere Pro CS3 vs CS4
                  hughie49 Level 1
                  OK,
                  I want to update CS3 to CS4 keeping ULTRA working. Since I am currently running on WIN XP Pro (32 bit)  with Matrox AXIO LE and I already have 4 processors and 8 gigs of ram, how about I get VISTA 64 bit. Can I still keep my favorite ULTRA program from CS3  ) Since I have it...I want to keep it. I was told that in the Win Vista 64 install, there is a provision for keeping some 32 bit programs working. If that is the case than perhaps I can run CS3 (32 bit) Flash with it's small footprint and install the whole (stand alone) ULTRA and have it functioning.
                  Any thoughts out there?
                  Hughie
                  Long Island NY
                  • 6. Re: Premiere Pro CS3 vs CS4
                    Instead of Vista, get Windows 7 Professional 64 bits version, the best version IMO.
                    • 7. Re: Premiere Pro CS3 vs CS4
                      dradeke Adobe Employee
                      ...but only if Matrox officially supports it which I'm guessing they don't right now....
                      • 8. Re: Premiere Pro CS3 vs CS4
                        hughie49 Level 1
                        Yes. Matrox is working on a WINDOWS 7 driver set for their AXIO LE system. No release date is set at this time. My Editor is using VISTA 64 bit w/ Adobe CS4 suite on his own system and says that he has no problem with it.
                        As I mentioned on Adobe site, my primary intrest is to make sure that the ULTRA (Serious Magic) software will keep working for me. I have an entire wall/floor chromakey painted. Aside from the four extra Virtual Reality Sets I also have 5 sets of "REALITY SETS" which were made for the ULTRA software. They feature actual live sets (Indoor & Outdoor) with multiple Alpha channels. This is why I am so intent in keeping the ULTRA programs running.
                        Thanks for your help in this.
                        Hughie
                        JHD Productions Ltd
                        www.jhdproductionsltd.com
                        • 9. Re: Premiere Pro CS3 vs CS4
                          That is a very nice collection to use with Ultra. I have the MSL's but never seen a Virtual Reality set. Care to show some screenshots of the most remarkable results with those?
                          • 10. Re: Premiere Pro CS3 vs CS4
                            hughie49 Level 1
                            Go to their website: realitysets.com. They have examples of several sets on there.
                            I now have 16 DVD's of their sets including the Las Vegas set. They don't do a very good job of keying the talent (you can see the blue splash from the key on talent's face.) If that happens a simple small face side light with a straw (light yellow) filter will get rid of the blue splash.
                            Hughie
                            My website has a few REALITY shots on it aswell as the Virtual sets from Adobe (Serious Magic)
                            • 11. Re: Premiere Pro CS3 vs CS4
                              Thanks for the info. I'll have a closer look.
