2 Replies Latest reply on Aug 13, 2009 12:47 PM by dr.Evol
    Charting: vertical axis position
    dr.Evol Level 1
      Hi!
      I need to manually position the vertical axis along the chart by setting the verticalAxisRenderer.x value.
      If I do that, it seem like chart compoenent automatically correncts the axis to be on the left side.
      Any ideas?
        • 1. Re: Charting: vertical axis position
          msakrejda Level 4
          If you're just looking to position it on the right, there is the 'placement' property of the AxisRenderer.
          Maciek Sakrejda
          Truviso, Inc.
          www.truviso.com
          Truviso is hiring: http://www.truviso.com/company-careers.php?i=87
          • 2. Re: Charting: vertical axis position
            dr.Evol Level 1
            Thanks for your suggestion but I need to position the axis anywhere like axis.x=500;
            I was playing arround for a few hours and so far I have came to the following solution which looks promising so far:
            I created a custom axis renderer which extends AxisRenderer. Then I tricked the chart component that it cannot set the x value of the axisRenderer.
            So.. if anyone come the the same problem in the future, this might be a solution.
            package si.catalina.qos.views.reports.charts.cartesianChart
                import mx.charts.AxisRenderer;
                public class CustomPositionAxisRenderer extends AxisRenderer
                    private var _xValue:Number=0;
                    public function CustomPositionAxisRenderer()
                        super();
                    override public function set x(value:Number):void
                        _xValue=value;
                    override public function get x():Number
                        return _xValue;
                    public function set xValue(value:Number):void
                        _xValue=value;
                    override public function move(x:Number, y:Number):void
                        super.move(_xValue,y);
