0 Replies Latest reply on Aug 13, 2009 8:28 AM by CoreyRLucier
    [svn:fx-trunk] 9270: Preliminary checkin of the 4+ runtime design layer feature.
    CoreyRLucier Adobe Employee
      Revision: 9270
      Author:   clucier@adobe.com
      Date:     2009-08-13 08:27:57 -0700 (Thu, 13 Aug 2009)
      Log Message:
      Preliminary checkin of the 4+ runtime design layer feature.  Note that this is being committed primarily so that the tooling folks can start playing.  We've yet to integrate spec or PARB feedback
      as such QE does not yet need to test.
      QE notes: No need to test just yet.
      Doc notes: Ditto
      Bugs: N/A
      Reviewer: Glenn / Paul
      Tests run: Checkin
      Is noteworthy for integration: Yes, Catalyst/FB may enable feature to begin integration if so desired.  Enable with compiler flag "-enable-runtime-design-layers".
      Modified Paths:
          flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/TextGraphicE lement.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Analyzer.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DesignLayerNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/SyntaxTreeBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ValueNodeHandler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
          flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/DesignLayer.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/LayeredNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/DesignLayer.java
