This content has been marked as final.
Show 4 replies
1. Re: Workaround: RH7 hangs when opening topics
Peter Grainge Jul 31, 2008 1:27 AM (in response to Deel1)Welcome to the forum.
I have never known Outlook cause any issues with RH and I don't think I have seen anyone post to that effect.
Are your projects on your local drive (good) or on a network (bad, except via source control).
2. Re: Workaround: RH7 hangs when opening topics
Deel1 Jul 31, 2008 6:35 AM (in response to Peter Grainge)Thanks, Peter. To answer your question, I keep my projects on my local drive. -
3. Re: Workaround: RH7 hangs when opening topics
Peter Grainge Jul 31, 2008 7:06 AM (in response to Deel1)Open one of the supplied sample projects and see how well they work.
You are working directly on the PC to which RH was installed?
No source control involved?
4. Re: Workaround: RH7 hangs when opening topics
Deel1 Aug 1, 2008 9:09 AM (in response to Peter Grainge)I am working directly on the PC to which RH is installed, and I am not using source control.
I tried the sample projects and had no problems opening topics, though there are also times when I have no problems opening topics in my own project (as I mentioned, the bad behavior doesn't happen consistently).
Maybe certain characteristics of my project are contributing to the problem. The project was converted from RoboHelp X5, for one thing. It's also large (>50MB), and the topics are all in one directory instead of being organized into subdirectories (something I'm hoping to remedy when I have time; I inhereited the project only recently).
Still, I don't see how any of those issues would be overcome simply by closing Outlook.
It's pretty odd.
