I'd like to use the first 'chapter/book' of my WebHelp (FH7) project as a Quick Start Guide and I think I can do it with a separate TOC.
I figured out how to do that part. But what I don't understand is, after I generate my project using the 2nd TOC, what/how do I deliver to the developers? They'll need both.
Hi there
You cannot use two TOCs in output. You will need to deliver separate outputs if you need two TOCs.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks for the reply.
Now my next question is, what does "deliver separate outputs" mean?
Does it mean I generate with the Quick Start toc, post those files, then do the same with the full toc? Won't that mean I'll have posted 2 Help systems with the same name?
Hi again
Indeed it does mean you will end up with two different help systems. The name may be the same because you will place them in different folders.
You may wish to think about creating a merged setup. Fortunately, fellow Adobe Community Expert Peter Grainge has some excellent information on his site about all that.
Click here to visit Peter's site
Cheers... Rick
