8 Replies Latest reply on Jul 31, 2008 3:50 PM by terry fude
    problems with how avant displays my template
    terry fude
      I made this template and it does not display correctly in Avant,
      i detached the template from thi page and this is what show in design view, any ways to fix it and reattach the template correctly?
        • 1. Re: problems with how avant displays my template
          Level 7
          What is Avant?
          > <BASE
          > HREF="file:///C:/Documents%20and%20Settings/t/My%20Documents/My%20Web%20Sites/wi
          > sdeerhunters/Templates/">
          This is pointing at your hard drive, which means it will not work for anyone
          else looking at your web site.
          -Darrel
          • 2. Re: problems with how avant displays my template
            Level 7
            Avant the web browser? I thought that died when IE7 was brought out. As I
            recall, Avant is IE6 with Tabs (and a few extras). Does the page look OK in
            IE6, or is it broken there as well?
            What is the URL for the page so people can check it in different browsers.
            The first line you've quoted is not valid HTML at that position - you can
            delete it, or move it into the head section; otherwise it will be throwing
            browsers into quirks mode.
            HTH,
            Pete.
            Peter Connolly
            http://www.kpdirection.com
            Utah
            • 3. Re: problems with how avant displays my template
              terry fude Level 1
              yes its on my HD, any way the page displays wrong in design view also, everything is moved around
              here is what it should look like, www.wisdeerhunters.com
              events page
              i would have atrtached the code from design view but it was too many bytes, so i will try to split it into 2 or 3 replies
              • 4. Re: problems with how avant displays my template
                terry fude Level 1
                <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                <html xmlns=" http://www.w3.org/1999/xhtml">
                <head>
                <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                <title>Wisconsin Deerhunters Events</title>
                <style type="text/css">
                body {
                background-image: url(Images/1%20beige019.jpg);
                .style3 {color: #000066}
                .wisdeer_address {font-family: Arial, Helvetica, sans-serif}
                .style6 {
                font-family: Arial, Helvetica, sans-serif;
                font-size: 24px;
                .style7 {
                font-size: 18px
                .style8 {color: #990000}
                .style9 {font-size: 18px; color: #990000; }
                .style14 {font-size: 24px}
                </style>
                function MM_preloadImages() { //v3.0
                var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
                var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
                if (a .indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
                function MM_findObj(n, d) { //v4.01
                var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
                d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
                if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms [n];
                for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers
                .document);
                if(!x && d.getElementById) x=d.getElementById(n); return x;
                function MM_nbGroup(event, grpName) { //v6.0
                var i,img,nbArr,args=MM_nbGroup.arguments;
                if (event == "init" && args.length > 2) {
                if ((img = MM_findObj(args[2])) != null && !img.MM_init) {
                img.MM_init = true; img.MM_up = args[3]; img.MM_dn = img.src;
                if ((nbArr = document[grpName]) == null) nbArr = document[grpName] = new Array();
                nbArr[nbArr.length] = img;
                for (i=4; i < args.length-1; i+=2) if ((img = MM_findObj(args )) != null) {
                if (!img.MM_up) img.MM_up = img.src;
                img.src = img.MM_dn = args[i+1];
                } else if (event == "over") {
                document.MM_nbOver = nbArr = new Array();
                for (i=1; i < args.length-1; i+=3) if ((img = MM_findObj(args
                )) != null) {
                img.src = (img.MM_dn && args[i+2]) ? args[i+2] : ((args[i+1])? args[i+1] : img.MM_up);
                } else if (event == "out" ) {
                for (i=0; i < document.MM_nbOver.length; i++) {
                img = document.MM_nbOver ; img.src = (img.MM_dn) ? img.MM_dn : img.MM_up; }
                } else if (event == "down") {
                nbArr = document[grpName];
                if (nbArr)
                for (i=0; i < nbArr.length; i++) { img=nbArr
                ; img.src = img.MM_up; img.MM_dn = 0; }
                document[grpName] = nbArr = new Array();
                for (i=2; i < args.length-1; i+=2) if ((img = MM_findObj(args )) != null) {
                img.src = img.MM_dn = (args[i+1])? args[i+1] : img.MM_up;
                • 5. Re: problems with how avant displays my template
                  terry fude Level 1
                  </script>
                  <meta name="Microsoft Theme" content="canvas 011, default">
                  </head>
                  <body onload="MM_preloadImages('Images/web buttons/home dn.png','Images/web buttons/chapters dn.png','Images/web buttons/newsletter_dn.png','Images/web buttons/projects_up.png','Images/web buttons/photos dn.png','Images/web buttons/forum dn.png','Images/web buttons/membership dn.png','Images/web buttons/events_dn.png','Images/web buttons/news_dn.png')" background="../_themes/canvas/cnvbkgnd.jpg" bgcolor="#FFFFFF" text="#000000" link="#0066CC" vlink="#006666" alink="#996699">
                  <div align="center">
                  <table width="900" height="1013" border="3" align="center" cellpadding="1" cellspacing="1" bordercolordark="#336666" bordercolorlight="#669999">
                  <tr>
                  <td width="16" rowspan="4" align="center" valign="top"><div align="left"><img src="Images/line2.png" alt="line" width="14" height="1500" align="top" /></div></td>
                  <td width="250" height="238"><div align="center"><img src="Images/deer_8.gif" alt="wi deer logo" width="250" height="250" /></div></td>
                  <td width="488"><div align="center">
                  <h1 class="wisdeer_address style3"><!--mstheme--><font color="#336666">Welcome to:<!--mstheme--></font></h1>
                  <h1 class="wisdeer_address"><!--mstheme--><font color="#336666"><span class="style3"><strong>Wisconsin Deerhunters, Inc.</strong><br />
                  State Headquarters P.O. Box 48 <br />
                  Neshkoro, WI  54960</span><!--mstheme--></font></h1>
                  </div></td>
                  <td width="19" rowspan="4" align="center" valign="top"><div align="right"><img src="Images/line2.gif" alt="line" width="14" height="1500" align="top" /></div></td>
                  </tr>
                  <tr>
                  <td height="72" colspan="2"><div align="center">
                  <table width="800" border="0" align="center" cellpadding="1" cellspacing="1">
                  <tr>
                  <td><a href="index.html" target="_top" onclick="MM_nbGroup('down','group1','Home','Images/web buttons/home dn.png',1)" onmouseover="MM_nbGroup('over','Home','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/home up.png" alt="Home" name="Home" width="125" height="35" border="0" id="Home" onload="" /></a></td>
                  <td><a href="chapters.html" target="_top" onclick="MM_nbGroup('down','group1','Chapters','Images/web buttons/chapters dn.png',1)" onmouseover="MM_nbGroup('over','Chapters','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/chapters up.png" alt="chapters" name="Chapters" width="125" height="35" border="0" id="Chapters" onload="" /></a></td>
                  <td><a href="newsletter.html" target="_top" onclick="MM_nbGroup('down','group1','Newsletter','Images/web buttons/newsletter_dn.png',1)" onmouseover="MM_nbGroup('over','Newsletter','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/newsletter_ up.png" alt="newsletter" name="Newsletter" width="125" height="35" border="0" id="Newsletter" onload="" /></a></td>
                  <td><a href="events.html" target="_top" onclick="MM_nbGroup('down','group1','Events','Images/web buttons/events_dn.png',1)" onmouseover="MM_nbGroup('over','Events','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/events up.png" alt="events" name="Events" width="125" height="35" border="0" id="Events" onload="" /></a></td>
                  <td><a href="photos.html" target="_top" onclick="MM_nbGroup('down','group1','Photos','Images/web buttons/photos dn.png',1)" onmouseover="MM_nbGroup('over','Photos','','',1)" onmouseout="MM_nbGroup('out')"></a></td>
                  </tr>
                  • 6. Re: problems with how avant displays my template
                    terry fude Level 1
                    <tr>
                    <td> </td>
                    <td> </td>
                    <td> </td>
                    <td> </td>
                    <td> </td>
                    </tr>
                    <tr>
                    <td><a href="news.html" target="_top" onClick="MM_nbGroup('down','group1','News','Images/web buttons/news_dn.png',1)" onMouseOver="MM_nbGroup('over','News','','',1)" onMouseOut="MM_nbGroup('out')"><img name="News" src="Images/web buttons/news up.png" border="0" alt="" onLoad="" /></a></td>
                    <td><a href="projects.html" target="_top" onclick="MM_nbGroup('down','group1','Projects','Images/web buttons/projects_up.png',1)" onmouseover="MM_nbGroup('over','Projects','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/projects up.png" alt="projects" name="Projects" border="0" id="Projects" onload="" /></a> <a href="events.html" target="_top" onclick="MM_nbGroup('down','group1','Forum','Images/web buttons/forum dn.png',1)" onmouseover="MM_nbGroup('over','Forum','','',1)" onmouseout="MM_nbGroup('out')"></a></td>
                    <td><a href="photos2.html" target="_top" onclick="MM_nbGroup('down','group1','Photos','Images/web buttons/photos dn.png',1)" onmouseover="MM_nbGroup('over','Photos','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/photos up.png" alt="photos" name="Photos" width="125" height="35" border="0" id="Photos" onload="" /></a></td>
                    <td><a href="membership_form.html" target="_blank" onclick="MM_nbGroup('down','group1','Membership','Images/web buttons/membership dn.png',1)" onmouseover="MM_nbGroup('over','Membership','','',1)" onmouseout="MM_nbGroup('out')"><img src="Images/web buttons/membership up.png" alt="membership" name="Membership" width="125" height="35" border="0" id="Membership" onload="" /></a></td>
                    <td><a href="events.html" target="_top" onclick="MM_nbGroup('down','group1','Events','Images/web buttons/events_dn.png',1)" onmouseover="MM_nbGroup('over','Events','','',1)" onmouseout="MM_nbGroup('out')"></a></td>
                    </tr>
                    </table>
                    </div></td>
                    </tr>
                    <tr>
                    <td colspan="2" valign="top"><div align="center">
                    <h1 class="style3"><!--mstheme--><font color="#336666">Events </font><font color="#336666"><!--mstheme--></font></h1>
                    </div></td>
                    </tr>
                    <tr>
                    <td height="615" colspan="2" align="center" valign="top"><table width="197" height="386" border="3" align="left" cellpadding="1" cellspacing="1" bordercolordark="#336666" bordercolorlight="#669999">
                    <tr>
                    <td align="center" valign="top" class="style6"><p class="style7"> </p>
                    <p> </p></td>
                    </tr>
                    </table> <div align="left">
                    <p><img src="Images/Wis deer booth2.jpg" alt="booth pic" width="500" height="382" align="top" /></p>
                    <p> </p>
                    <p align="center"><span class="style14"><a href="Images/Local Chapters Banquets.doc" title="banquet info" target="_blank"></a></span></p>
                    <h1 align="center"><!--mstheme--><font color="#336666"><em>Local Chapters Banquets<br />
                    </em><!--mstheme--></font></h1>
                    <table width="806" height="333" border="1" align="center" cellpadding="0" cellspacing="0" bordercolordark="#336666" bordercolorlight="#669999">
                    <tr>
                    <td width="338" height="327" align="center" valign="top"><div align="center">
                    <!--msthemelist--><table border="0" cellpadding="0" cellspacing="0" width="100%">
                    <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul2.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">
                    <div align="center" class="style9">North Central Chapter/Edgar/<br />
                    March 22nd<br />
                    Call: Jerry  (715) 352-2547<br />
                    <br />
                    </div>
                    <!--msthemelist--></td></tr>
                    <div align="center" class="style9">Witt-Birn Chapter/<br />
                    Birnamwood/Mar 29th<br />
                    Call: Dan (715) 302-1327<br />
                    <br />
                    • 7. Re: problems with how avant displays my template
                      terry fude Level 1
                      </div>
                      <div align="center" class="style9">Fox River Chapter<br />
                      Princeton/May 17th<br />
                      Call: Virginia (920) 293-4141<br />
                      <br />
                      </div>
                      <div align="center" class="style9">Northwinds Chapter<br />
                      Marion/Aug 22nd<br />
                      Call: Bob (715) 754-2603<br />
                      <br />
                      </div>
                      <div align="center" class="style9">ManitowocCountyChapter<br />
                      Manitowoc/Sept. 11th<br />
                      Call: Clarence (920) 794-8718<br />
                      <br />
                      </div>
                      <div align="center"><span class="style9">Fox-Wolf Chapter/<br />
                      Appleton/Sept 12th<br />
                      Call: Kevin (920) 738-9028</span><br />
                      </div>
                      <!--msthemelist--></table>
                      </td>
                      <td width="398" align="center" valign="top"><div align="center">
                      <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul3.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">Woodland Chapter/Gresham/October 20th<br />
                      Call: Charlie (715) 524-4813<br />
                      <br />
                      <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul3.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">Shawano Chapter/Shawano/Nov 6th<br />
                      Call: Bill (715) 526-3719<br />
                      <br />
                      <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul3.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">Northeast Wisconsin Chapter/Green Bay/<br />
                      Call for Banquet date/<br />
                      Call: Terry  (920) 338-0854<br />
                      <br />
                      <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul3.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">Southeast Wisconsin Chapter<br />
                      /Milwaukee Area/<br />
                      Call: Mike  (262) 252-4137<br />
                      <br />
                      <!--msthemelist--><tr><td valign="baseline" width="42"><img src="../_themes/canvas/acnvbul3.gif" width="12" height="12" hspace="15" alt="bullet"></td><td valign="top" width="100%">Holy Hill Chapter/Colgate/<br />
                      Call for Banquet date<br />
                      Call: Mike (262) 628-4180 <!--msthemelist--></td></tr>
                      </td>
                      </tr>
                      </table>
                      <p align="center"><a href="Images/Local Chapters Banquets.doc" title="banquet info" target="_blank">Printer Friendly Version of Banquet Info</a></p>
                      </div></td>
                      </tr>
                      </table>
                      </div>
                      </body>
                      </html>
                      • 8. Re: problems with how avant displays my template
                        terry fude Level 1
                        thanks for all the help
