0 Replies Latest reply on Aug 13, 2009 10:56 AM by MaxManNH
    FLVPlayback component protocol
    MaxManNH Level 2
      Can anyone tell me if this is accurate?
      With Flash CS3 if you specify RTMP the default port is 1935 for streaming video from Flash Media Server. If the Flash Player is unable to make a connection over port 1935 it will attempt subsequent ports until it finds a connection. If it cannot find a connection it will not play the video stream.
      This much I am sure is accurate. Now in the process of rolling ports does the FLVPlayback also roll protocols?
      So if I specify RTMP and the FLVPlayback control cannot make an RTMP connection will it then attempt connections with RTMPT? Or do I need to do something to fall back to RTMPT?
