0 Replies Latest reply on Aug 13, 2009 11:31 AM by Paul Reilly
    [svn:fx-trunk] 9272: * Fixed asserts when compiling SDK projects with Flash Builder.
    Paul Reilly Level 1
      Revision: 9272
      Author:   preilly@adobe.com
      Date:     2009-08-13 11:31:45 -0700 (Thu, 13 Aug 2009)
      Log Message:
      • Fixed asserts when compiling SDK projects with Flash Builder.
      QE notes:
      Doc notes:
      Bugs: SDK-22560
      Reviewer: Peter D.
      Cycloner: Gaurav
      Tests run: checkintests
      Is noteworthy for integration:
      Code-level description of changes:
        Source.java
          Modified copyCompilationUnit() by adding a useHistories flag,
          which toggles copying the MultiNames from the histories back into
          the dependency lists when making a copy.  For copies of SWC based
          CompilationUnits, we don't want to use the histories.  For all
          other CompilationUnits, we do.
          Modified copy() to pass true into copyCompilationUnit().
        CompilerSwcContext.java
          Modified getSource() to pass false into copyCompilationUnit().
        as3/As3Compiler.java
          Removed a bunch of unnecessary checks for a null symbolTable.
          Modified analyze1() to clear out fa_unresolved.
          Modified transferDependencies() to handle UnresolvedNamespace
          instances by plucking out the name of the wrapped ReferenceValue.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22560
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerSwcContext.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
