4 Replies Latest reply on Aug 14, 2009 9:33 PM by Gregory Lafrance
    Question on Flex Component
    csr_1978
      I have two components and i am trying to display pre-defined component1 state from component2 when a button is clicked.
      My Code in Component2 to acheive this:
      private function displayComponent1():void
           var comp1:Component1;
           comp1.currentState = 'addState';
      I get this run time exception:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      so i changed my code to
           var comp1:Component1 = new Component1();
      I dont get any exceptions but its not displaying component1. Can any one please help me out.
      csr
        • 1. Re: Question on Flex Component
          FlexAppsStore.com
          Hello,
               If I understand what you are looking, it sounds like you need to use the full domain path when setting the state.
          For example:
          private function displayComp():void {
               com.mycomps.comp1.currentState = 'addState';
          This assumes that you have setup an XMLNS for you comps.
          Kind regards,
          Ivan Alexander
          FlexAppsStore.com
          • 2. Re: Question on Flex Component
            Gregory Lafrance Level 6
            You need to use addChild() to add comp1 to the display list:
            private function displayComponent1():void{
                this.addChild(comp1);
            If this post answers your question or helps, please mark it as such.
            • 3. Re: Question on Flex Component
              csr_1978 Level 1
              adding
              works but this adds component1 inside component2 so i get two panels displayed one from component1 and other from component2 but i just want to display component1. is there any way that i can just forward it to component1?
              • 4. Re: Question on Flex Component
                I'm not exactly sure what you are trying to do. You seem to have a main app, and component 1 and component 2.
                If you are trying to add component1 to the main app instead of to component2, then:
                mx.core.Application.application.addChild(comp1);
