This content has been marked as final.
Show 2 replies
1. Re: Help - Can't revert to original or change the transcode settings.
nados Aug 13, 2009 3:28 PM (in response to nados)Ok...
I solved the not being able to "revert to original" blu-ray transcode problem. Appearently, you need to make sure the "Project Settings" reflect the correct authoring mode and codec. In my case, it must be set to "blu-ray" otherwise Encore keeps looking at the "dvd" side of things. After i changed the authoring mode, i was able to revert the blu-ray transcode and was able to set the transcode to whatever i wanted.
Also, the Adobe Encore message: "This file has already been transcoded." when i tried to check "Use Maximum Render Quality" in the Transcode Settings window - is gone.
2. Re: Help - Can't revert to original or change the transcode settings.
Bill Hunt Aug 14, 2009 12:21 PM (in response to nados)Have not encountered this. I wonder if clearing the Media Cache, including the Transcodes, will bring this setting back?
Good luck, and please report,
