4 Replies Latest reply on Aug 14, 2009 12:03 AM by Virat Patel
    creation complete
    Seglespaan Level 1
      am I right in thining for a view stack, the creation complete will fire every time that view is enabled? or is it just the first time?
        • 1. Re: creation complete
          Seglespaan Level 1
          ok so I've worked out that creation complete will only fire the first time a view in a stack is loaded / viewed.
          However whayt I need is this,
          I have a viewstack with two views, view 1 and view 2, each time a view is loaded I want to call a function which will in turn populate the view stack, any ideas how I can call this time each time a view is loaded?
          Cheers
          Tim
          • 2. Re: creation complete
            FlexAppsStore.com
            Hello,
                 Give this a try. On the Canvas or Panel or whatever it is in your viewstack use the show event to fire the action.
            Example:
            <mx:ViewStack id="vs1">
                 <mx:Canvas id="can1" label="Customers" show="Alert.show('Fires when showed')"/>
            </mx:ViewStack>
            • 3. Re: creation complete
              Virat Patel
              Hello
              As you require to load data every time when view of viewstack is being changed.
              There is two way to do samething.
              1. You can use viewstack change event
              in this you willl get  oldindex and newindex of viewsatck so as per that you can load or unload the data as per requirement
              2. You can use 'show' event of childern inside the viewstack
              in this 'show' event is fiered when any child inside view stack is in visible mode, so you can do for that viw also.
              With Regards
              Virat Patel
              • 4. Re: creation complete
                Virat Patel Level 2
                Hello
                This can be possible is two ways
                Like you can use 'change' event of the viewstack or 'show' event of the childs inside viewstack.
                Sample Example...
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
                     <mx:Script>
                         <![CDATA[
                             import mx.events.IndexChangedEvent;
                             import mx.events.FlexEvent;
                             private function onCanShow(event:FlexEvent):void
                                 // load new data
                                 // do something
                             private function onChildChange(event:IndexChangedEvent):void
                                 // load new data
                                 // do something
                     </mx:Script>
                     <mx:TabBar dataProvider="{vs}" />
                     <mx:ViewStack id="vs" height="400" width="400" change="onChildChange(event)">
                         <mx:Canvas label="Can1" height="100%" width="100%"
                             backgroundColor="0xCCCCCC" show="onCanShow(event)" />
                         <mx:Canvas label="Can2" height="100%" width="100%"
                             backgroundColor="0x00FFCC" show="onCanShow(event)" />
                     </mx:ViewStack>
                </mx:Application>
                With Regards
                Virat Patel
