0 Replies Latest reply on Aug 13, 2009 3:54 PM by Chet Haase
    [svn:fx-trunk] 9287: Fixes bug with shader-transition effects ( AnimateTransitionShader, Wipe, and CrossFade) when acting on targets that either have filters or are inside a hierarchy with filters .
    Chet Haase
      Revision: 9287
      Author:   chaase@adobe.com
      Date:     2009-08-13 15:53:43 -0700 (Thu, 13 Aug 2009)
      Log Message:
      Fixes bug with shader-transition effects (AnimateTransitionShader, Wipe, and CrossFade) when acting on targets that either have filters or are inside a hierarchy with filters. Fix was to capture the bitmap snapshot of the target without any of its own filters applied and to then use the ShaderFilter in conjunction with the target's filters during the animation.
      QE notes: Probably need more tests in this area, now that we handle it
      Doc notes: none
      Bugs: sdk-20250
      Reviewer: Jason
      Tests run: Checkintests, Mustella (spark/effects/[AnimateTransitionShader|Wipe|CrossFade])
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-20250
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransitionShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransiti onShaderInstance.as
