3 Replies Latest reply on Aug 13, 2009 9:20 PM by btk_ola
    seeking basic script help
      hello flash forum-
      i will start with my question and leave the explanation for later...
      i am looking for real simple scripting- i have a 15-25 frame flash tweened animation, and all i would like to do is run thru the animation once then on mouse click go to frame one and start again... and of course i am under a time crunch and completley fogged with actionscript 3.0
      yes, i did some basic projects back in the director days and thought i could just pick up where i left off... if i remember right it was simple scripting like
      etc... sheeesh! do i feel lame! thanks very much in advance for any and all help
        • 1. Re: seeking basic script help
          thepixelsmith Level 2
          This is a two part solution. First stop the timeline from automatically playing again and then create an event listener that allows you to run a function based on a mouseClick.
          In the last frame of your timeline:
          Step 1: Create a stop function
          Step 2: Create an Event Listener to listen for a MouseClick. This assumes you want to have a button trigger the playback. I used a generic name and assumed that you were using a MovieClip as the button.
          myMC_mc.addEventListener(MouseEvent.MOUSE_DOWN, myFunction);
          Step 3: Create the function that is listed at the end of the event listener. It will be triggered whenever the listener runs.
          function myFunction(myEvent:MouseEvent):void {
          If you don't want to use a button you could use an event listener tied to the stage itself:
          stage.addEventListener(MouseEvent.MOUSE_DOWN, myFunction);
          • 2. Re: seeking basic script help
            Repeated info removed
            • 3. Re: seeking basic script help
              btk_ola Level 1
              thank you very much! soon as i get this out im hittin the books!
              thanks again
