9 Replies Latest reply on Aug 14, 2009 9:55 AM by KimJolly
    Capture in Premier Pro CS3...please help
    KimJolly
      OK...I am BRAND NEW at Premier and "video" all together.  I'm trying to Capture video footage using my Sony DCR-SX41 camcorder AND I've watched the Lynda.com video on how to "capture" footage.  The instructor says that I may have problems doing this (which I certainly do), if my camera isn't set to "VCR mode"...what the HECK is that.  I'm looking through every setting on my camera and I don't see a "VCR mode".  Can someone help?! THANKS!
      SIGNED..."TOTALLY DISCOURAGED"
        • 1. Re: Capture in Premier Pro CS3...please help
          Curt Wrigley Level 4
          Most cameras have a switch that has 3 positions:  Off, Camera Mode, VCR Mode
          VCR mode may be called something different, like VTR or Playback
          • 2. Re: Capture in Premier Pro CS3...please help
            Just looked up your camera.  It doesnt have a firewire port, so you cant connect it to a computer for video capture.
            Your cam records video onto a flash card, it loks like in MPG2 format.   So, just copy the files over and try it.   However you might like premiere elements better if this is going to be your source video.  Its designed for lower end video.
            Im just curious, cause this seems to happen alot..  Why do you buy an $800 editing sw to go with a $300 camera?  Pr Elements is only around $99
            • 3. Re: Capture in Premier Pro CS3...please help
              Stan Jones Adobe Community Professional & MVP
              Some Sonys have an on/off and a "mode" setting past "on" that toggles between "camera" and "play/edit."  You want "play/edit" if that is your camera's system.  When you first turn such cameras on, they default to camera, and won't respond to capture commands.
              • 4. Re: Capture in Premier Pro CS3...please help
                KimJolly Level 1
                ...The short answer to your question is "I'm clueless".  I'm more accustomed to doing print work and I'm trying to break into video...Thanks for your help.  I'll try Elements.
                • 5. Re: Capture in Premier Pro CS3...please help
                  KimJolly Level 1
                  Since I can't do CAPTURE with my camera.  I saved the video on my computer and tried to import it (MPG2 format) into Premiere.  It brought in the VIDEO but not the AUDIO.  Am I doing something wrong?
                  • 6. Re: Capture in Premier Pro CS3...please help
                    Harm Millaard Level 7
                    I suggest you first get a proper education in video editing. Then get a consumer application like the free WMM, or PE. That is a $ 99 program that suits your capabilities much better than a $ 799 program like PR.
                    What makes you think that a $ 269 camera is worth an expensive program like PR, when the camera does not deliver material suitable for editing, only for watching?
                    • 7. Re: Capture in Premier Pro CS3...please help
                      The first question at the end of this link http://ppro.wikia.com/wiki/Troubleshooting includes links to software that will tell you the CODEC used for your file
                      If you don't have the correct CODEC installed, Premiere won't work... IF it will work at all with the files you have
                      When you get to the wiki link, go to the base of that "tree" and start reading... especially the tutorial section
                      Also... go to my notes page http://www.pacifier.com/~jtsmith/ADOBE.HTM and click the link about editing Compressed files
                      There may be other software that would work better with your camera
                      • 8. Re: Capture in Premier Pro CS3...please help
                        Jim_Simon Level 8
                        Yes.  The correct sequence here is first learn, and then do.  You're trying to skip step one.
                        Like Harm said, a proper education in video production is really the best place to start for anyone wanting to use Premiere Pro.  For the rest, there are plenty of consumer programs out there.  (As well as professionals like myself who actually earn our living doing this kind of thing.  Don't be shy about hiring a local videographer if you don't know what you're doing.  Believe me, we need the work.)
                        • 9. Re: Capture in Premier Pro CS3...please help
                          KimJolly Level 1
                          Yikes...Looks like I touched a nerve among the experts...apologies.  I'm a novice and am trying to learn which is why I joined the forum, joined Lynda.com and purchased a myriad of different books.  But, "I don't know what I don't know"...which is why I asked.  I had already purchased CS3 and just recently purchased the camcorder...not knowing what specific features I need in the camcorder to make it work w/ Premiere Pro (still not 100% clear)...and I'm working on a very limited budget, so I couldn't get the extremely expensive cameras.
                          Thanks everyone for your feedback.  I'll take your advice and will continue to do my best and learn as much as possible about the subject matter.
