4 Replies Latest reply on Aug 14, 2009 8:32 AM by Jed Schneider
    Walking the Tree
    Zolotoj Level 3
      Here is a sample of my tree:
      <menu name="46950 - MISSION ALLERGY" menuid="1" parentid="" link="" line_id="" salesrepid="" category="" folder="1">
        <menu name="COMMITMENTS" menuid="5" parentid="1" link="" line_id="" salesrepid="" category="" folder="1">
          <menu name="SHEET SET 060507.XLS" menuid="6" parentid="5" link="" line_id="" salesrepid="" category="" folder="0"/>
          <menu name="SHEET SETS 061908.XLSX" menuid="7" parentid="5" link="" line_id="" salesrepid="" category="" folder="0"/>
        </menu>
        <menu name="CORRESPONDENCE" menuid="8" parentid="1" link="" line_id="" salesrepid="" category="" folder="1">
          <menu name="2006" menuid="12" parentid="8" link="" line_id="" salesrepid="" category="" folder="1">
            <menu name="052406 400 TENCEL LYOCELL STRIPE SHEET SET.DOC" menuid="13" parentid="12" link="" line_id="" salesrepid="" category="" folder="0"/>
          </menu>
      I am starting walking out of it from:
      Here is my code:
      var parentArray:Array = new Array();
      var fullPath:String = "";
      parentArray.push(tree.selectedItem.@name);
      var parent:Object = tree.getParentItem(obj);
      while(parent != null)
        parentArray.push(parent["@name"]);
        obj = parent;
        parent = tree.getParentItem(obj);
      at the end parentArray will not have a root parent: "46950 - MISSION ALLERGY" becasue
      tree.getParentItem(obj) will return null for menuid="8". Why is that?
        • 1. Re: Walking the Tree
          Jed Schneider Level 1
          i assume you are getting this xml from a httpService call and your resultFormat is set to e4x, so put your xml inside a root tag, like <allMenus>. ResultEvent.event.result.menu will give you an xmlList of all your menus. then menus:XMLList = event.result.menu and menus[0] is the menu you are looking for.
          • 2. Re: Walking the Tree
            Zolotoj Level 3
            Yes, I understand that adding another "root" will help. But why it's not working in my case? Why do we need extra root?
            • 3. Re: Walking the Tree
              Zolotoj Level 3
              I think this is the right way:
                obj = parent;
                parent = tree.getParentItem(parent);
              // add root name
              parent = obj.parent();
              parentArray.push(parent.@name);
              • 4. Re: Walking the Tree
                well, first I'd make sure your xml passes validation, since it wont in the code snippet that you posted.
                Then I'd maybe try to do something like event.result.children(), its just a guess, but that should return an XML list, you may have to cast it first myXMLList = event.result as XMLList, hope that helps.
