1 Reply Latest reply on Aug 18, 2009 11:54 AM by Jasmin Charbonneau
    XPath issue
    Mancini21 Level 1
      Hi Guys,
      This is not working
      concat("c:\", getDocAttribute(/process_data/@inputDoc,"filename"),"pdf")
      The inputDoc variable is a document.
      I've tried to use "filename", "wsfilename" and it doesn't work.
      With "filename" it works, but only show me string "pdf", and i want to add the filename to "pdf".
      How can this works?
        • 1. Re: XPath issue
          Jasmin Charbonneau Level 4
          Can you try with just hard coding the name first. Something like
          concat("c:\", "myFile","pdf")
          then the slash might give you some trouble. Try to use a front slash instead like
          concat("c:/", "myFile","pdf")
          If this works, then we know the problem is just with the getDocAttribute function.
