3 Replies Latest reply on Aug 14, 2009 9:18 PM by Gregory Lafrance
    viewstack vs states
    SushiSnacks
      I've read in a couple places that's best to use a viewstack when doing a site in flex. What are the pros/cons of using a viewstack vs using states?
      thanks!
        • 1. Re: viewstack vs states
          FlexAppsStore.com
          Hello,
               Here's a good discussion around the subject.
               http://forums.adobe.com/message/2091015
               For us, it's always a design question. Do the screens interact or are the completely separate. If they are then states win, otherwise we use viewstacks.
               Also, you have to be careful when in a large app with your data assignments. Might want to check out "CreationPolicy" rules for performance as well.
          Kind regards,
          Ivan Alexander, PMP
          Flex Applications Engineer
          FlexAppsStore.com
          • 2. Re: viewstack vs states
            Ansury Level 3
            States suck, end of story.
            Just kidding, that's a good thread.  Yep the only thing I'd even consider states for is a small sized standalone component--but I rarely work on such things.  Not worth the trouble on a larger scale.  You can still do transition effects and everything without states.
            Also consider the fact that states are supposed to* change completely (how they are used and work) in Flex 4.  I'd at least stay away until I'm using SDK 4.
            *=I've yet to take a direct look myself
            • 3. Re: viewstack vs states
              Gregory Lafrance Level 6
              States should only be used for small components that change their UI in minor ways.
              ViewStack is the real workhorse in Flex for multi-screen apps.
              If this post answers your question or helps, please mark it as such.
