3 Replies Latest reply on Aug 16, 2009 4:55 AM by Gregory Lafrance
    How to use a variable to navigate through XML data
    ice1000
      My chart has xml data that looks like this:
      <getViewResponse>
         <getViewResult>
            <DocumentElement>
               <ColumnChart>
                  <Month>
                     "Dec"
                  <NetIncome>
                     1000
               <ColumnChart>
      etc.
      etc.
      the following lines in actionscript work perfectly to feed the chart:
      resultxml = event.result.getViewResult.DocumentElement.ColumnChart as XMLList
      //chart data provider
      _chartDP = new XMLListCollection(resultxml);
      The last Colum Chart argument in DocumentElement.ColumnChart is going to change. I want to make this a variable instead.
      I tried DocumentElement+'.'+this.[ColumnChart] but I get an error telling me the property does not exist.
      The following almost works:
      event.result.getViewWithTitlesResult.DocumentElement.*
      but my chart has an empty extra data series.
      How can I set that last element to a variable?
        • 1. Re: How to use a variable to navigate through XML data
          Gregory Lafrance Level 6
          How about this:
          var myVar:XML = _chartDP.getItemAt(_chartDP.length-1);
          If this post answers your question or helps, please mark it as such.
          • 2. Re: How to use a variable to navigate through XML data
            ice1000 Level 1
            I couldn't get your code to work. I got an error about implicit coercion not working.
            I have more info on my problem though. I browsed through the xml and it actually looks something like this:
            <ColumnChart>
               <Month>2006</Month>
               <NetIncome>-7393046.28695399</NetIncome>
            <ColumnChart>
            <ColumnChart>
               <Month>2007</Month>
               <NetIncome>77801003.0915078</NetIncome>
            <ColumnChart>
            <Info>
               <Table>Finance</Table>
               <View>ColumnChart</View>
            </Info>
            The chart is actually graphing the correct data set. I just happen to have an extra node in my XMLList. I researched and founf a function to remove a node from an XMLList.
            private function removeNode(node:XML):void {
              var cn:XMLList = XMLList(node.parent()).children();
              for (var i:Number=0;i<cn.length();i++) {
                if (cn[i]==node) {
                  delete node[i];
            I think this will work but in my original code my xml is an XMLList type. The above funtion is expecting a XML datatype.
            How do I extract the Info node as XML from an XMLList so I can pass it to the function?
            Thanks!
            • 3. Re: How to use a variable to navigate through XML data
              If the data you currently say is XMLList has just one item, just cast to XML with XML(myXMLLIST) or "myXMLLIST as Xml".
