0 Replies Latest reply on Aug 14, 2009 3:42 PM by Peter Farland
    [svn:fx-trunk] 9325: Significant update to fxgutils with initial support for FXG 2. 0 syntax and partial FXG 2.0 rich text support.
    Peter Farland Level 3
      Revision: 9325
      Author:   pfarland@adobe.com
      Date:     2009-08-14 15:42:35 -0700 (Fri, 14 Aug 2009)
      Log Message:
      Significant update to fxgutils with initial support for FXG 2.0 syntax and partial FXG 2.0 rich text support. Additional 2.0 features such as new blend modes are not yet supported.
      QE notes: Yes, apologies but 36 negative mxmlcunit tests will need to be updated as it appears fxgutils error messages have changed.
      Doc notes: None.
      Bugs: None
      Reviewer: Sujata and Min. Paul to review code gen in FlexFXG2SWFTranscoder.
      Tests run: checkintests, mxmlcunit fxg
      Is noteworthy for integration: Yes, contains FXG 2.0 awareness and initial support for FXG 2.0 text tags for optimized FXG scenario.
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGSymbolClass.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexGraphicNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexParagraphNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexSpanNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexTextGraphicNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGConstants.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGParser.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGVersion.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/BitmapGraphicNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContentNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/PathNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextGraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/BitmapFillNode. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/AbstractStrok eNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractCharacte rTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractTextNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/ParagraphNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/SpanNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BlendMode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/MaskType.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXParser.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ImageHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/TypeHelper.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexRichTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/CDATANode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RichTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich BlockTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich ParagraphNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextLeafNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/BRNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/DivNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/FormatNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/ImgNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkActiveFo rmatNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkHoverFor matNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkNormalFo rmatNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/ParagraphNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/SpanNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/TCYNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/TabNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/AlignmentBaseli ne.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BaselineShift.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BlockProgressio n.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/BreakOpportunit y.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/DigitCase.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/DigitWidth.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/Direction.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/DominantBaselin e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FirstBaselineOf fset.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FontStyle.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FontWeight.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/JustificationRu le.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/JustificationSt yle.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LeadingModel.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LigatureLevel.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LinkTarget.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/NumberAuto.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/NumberInherit.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/ResizeMode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/TextAlign.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/TextDecoration. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/TextJustify.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/TypographicCase .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/VerticalAlign.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/AbstractFXGVersionHan dler.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGVersionHandler.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGVersionHandlerRegi stry.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXG_v1_0_Handler.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXG_v2_0_Handler.java
      Removed Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/CDATANode.java
