1 Reply Latest reply on Aug 14, 2009 4:41 PM by alexManuelSilva
    load as xml
    alexManuelSilva
      I am trying to load a piece of html code as  xml from a given url but since one of the tags (meta) hasn´t been closed, my URLLoader is not able to load  it as xml. Is there any way of working around this problem?
      Sofar, all I have been able to do was to load it as a String and slice it in several points.
      Arrays don´t seem to work in this case.
      I tried, for example:
         var exp:String="blockquote"
         var exp_1:String="</p>";
         var ind:int=loader.data.indexOf(exp);
         var ind_1:int=loader.data.indexOf(exp_1,ind+1);
         var str:String=loader.data.slice(ind+exp.length+1,ind_1);
         var index:Array=str.toString.match("</ul>");
      and it returned an array of lenght 1 instead of 8;
      thanks for helping
      alex
      I
