26 Replies Latest reply on Aug 25, 2009 2:10 PM by the_wine_snob
    Moving tracks up and down...?
    Karel Bata Level 1
      So easy to do in PS AE etc, but a real mystery in PP...
      And is it possible to insert a track?
      Cheers!
        • 1. Re: Moving tracks up and down...?
          Harm Millaard Level 7
          The help is useful in some cases. This may be one of them. Drag and drop is one solution and insert track is another solution. Go to the menu and select Sequence/Add track... How difficult can it be, but there are other workflows.
          Sorry, but this is such a basic question that if you need to ask this, it is better to get a basic education first or consult the manual, help file and study some tutorial.
          • 2. Re: Moving tracks up and down...?
            Karel Bata Level 1
            Should I be using the word layers? Like in PS or AE? I always think of them as tracks, like in 'track laying'. Meanwhile the material within a track is a clip. I think the manual agrees with me.
            Yes, you can drag and drop a clip, but no you can't do that with tracks. Or I'm missing something.
            • 3. Re: Moving tracks up and down...?
              Have you read about nested sequences?
              • 4. Re: Moving tracks up and down...?
                Karel Bata Level 1
                Er, not exactly the first thing that jumped to mind...
                Relevant I take it though?
                I did search the manual. Honest, But what do you search for? tracks? move? It's not exactly helpful. But no, 'nesting' I didn't think of... Silly me.
                • 5. Re: Moving tracks up and down...?
                  To move a track up or down, as you put it, does not seem to be logical. What is the value of doing that? With clips, I understand this, because you want to overlay a lower clip with the clip above it. But the same applies to nested sequences. What is the value of moving a complete track up or down? What do you want to achieve?
                  • 6. Re: Moving tracks up and down...?
                    You cannot move tracks up and down.
                    Workaround is add a track and copy/cut content from 'old' track to 'new' track.
                    2 people found this helpful
                    • 7. Re: Moving tracks up and down...?
                      Karel Bata Level 1
                      Thanks.
                      But that is ridiculous. Moving tracks or layers is standard practice in so much other software.
                      I'm currently working on something that has (at its peak) five small windows with different clips with lots of edits running with their own effects. At times I've wanted to reprioritise a track (to put it above another) so just draggng a track up would have been a quick way of doing it.
                      How disappointing - and a shame the project is too long for AE!
                      Currently waiting to see if Encore (having spent an hour transcoding) decides to throw up another error message! And why doesn't it just say there's a problem an hour ago? "Legacy issues" I'm told on the relevant forum. Sheesh....
                      • 8. Re: Moving tracks up and down...?
                        Karel Bata Level 1
                        Yup "internal software error... PGC"
                        Again.
                        And no mention of PGC in the Adobe manual. The solution suggested in the Encore forum was to encode in NTSC, which worked. But you guys tell me that's wrong.
                        And Harm says I should take a course to stop asking silly questions...
                        • 9. Re: Moving tracks up and down...?
                          Colin Brougham Level 6
                          I assume you're talking about software like After Effects or Photoshop, which contain "layers" and not "tracks" in the way that Premiere Pro, and any other editor for that matter, have them . Perhaps it's a semantic difference, but it's an important one: in Adobe software, a "layer" contains one and only one footage item or graphical element, whereas a "track" can contain one or more footage items or graphical elements. In After Effects, you HAVE to seperate footage items by both time (X-axis) and stacking order (Y-axis)--that's simply how it works. However, with Premiere, you only necessarily have to seperate footage items by time (X-axis)--if you can do everything on one track, so be it.
                          If you were able to drag tracks up and down in the stacking order (Y-axis), you may be able to achieve the layering effect you want at a certain point in time in your sequence, but you would also change the stacking order for the entire duration of the sequence. This may be what you want, or what you don't want, but I would submit that most people would never need this kind of functionality. How often does one need to completely rearrange the stacking order of an entire sequence? I know that I never need this; it's only small portions of time where I need to rearrange items on the Y-axis. I just think this capability would be so rarely needed that there is no point adding it; it could potentially cause more trouble than good.
                          You might consider nesting each track (or track segment) in its own sequence, so at least you're only dragging one element up and down, instead of multiple small clips. Just add one empty track to serve as a temporary landing zone, that you can move an individual nest into, and then continue to reshuffle until you get the order you want. I realize this isn't what you really want, but it's the best workaround I can think of.
                          Why is it too long for AE? After Effects has something like a 3 or 4-hour limit to a comp, which I imagine would be pretty difficult for most people to exceed. It would be a bit of a pain to manage, I suppose, but you could do it.
                          Alternately, if you've got the suite and therefore Dynamic Link, just select the clips in the section of timeline you're trying to work with, and select Replace with After Effects Composition. That chunk of timeline will be sent to AE and the clips will be stacked as individual layers in the same order they're in in the PPro sequence. From there, you can organize and reorganize things to your heart's content, and that will be reflected in your PPro sequence. You may want to consider creating nested sequences in PPro first, because those will be recreated in your AE comp as nested precomps. Might make layer management a bit more friendly.
                          • 10. Re: Moving tracks up and down...?
                            Karel Bata Level 1
                            Thanks for a very comprehensive answer. Not sure I agree though - if you had that functionality you would find good uses for it. And coding for it is hardly rocket science. After all, Sony Vegas does it!
                            Virtually all music software, like ProTools, does it too. Within PT it actually changes nothing, but by grouping stuff together can make it easier to hang on to an overview of a complex project (and cause less strain on fingers if there's a hardware mixer attached). Of course with music the way plug-ins are implemented is rather different.
                            What now comes to mind is editing picture to music, or spot fx. Having the tracks next to each other really helps, so temporarily moving a track to the bottom adjacent to the audio would be very helpful.
                            I'll give this dynamic link thingy a go. Though I'm already on several new learning curves here...
                            Cheers!
                            p.s. I'm not totally new to video: http://forums.adobe.com/thread/416509
                            • 11. Re: Moving tracks up and down...?
                              You're welcome. And you certainly don't have to agree--diff'rent strokes for diff'rent folks. Because of the way I work, I really don't think I'd find it useful, but that's just me. I can't comment on the difficulty of coding such a feature, not being a software engineer. Seeing how Vegas began its life as an audio application, I can see how it may have originally had and then retained this capability.
                              You can't compare ProTools to Premiere Pro, at least not in the way tracks work between the two applications. As you correctly point out, when rearranging tracks in ProTools you're changing absolutely nothing about the way the output sounds--it's merely a convenience. It would be the equivalent of turning your stereo speakers upside-down and expecting the sound coming from them to be different. However, if you shuffle tracks in Premiere Pro (I'm talking about video tracks here), then the output IS different, since the compositing of video tracks works from the bottom up. For most people I think the potential of accidentally sliding a track out of place would represent a liability instead of an asset.
                              But that makes me wonder--are you talking about restacking audio tracks or video tracks?
                              I'm not following this, I guess. You can achieve much of the same functionality by enabling or disabling individual or groups of clips in a sequence, or by toggling the visibility of whole tracks in the timeline header area (punch out the eyeballs to turn a track on or off). Think of it as a solo or mute function as you'd have in an audio mixer. Come to think of it, I wish PPro had a "solo" capability much the way that AE does... hmm, feature request time.
                              I think you'll find that DL will help you do what you're trying to do. If you know AE well, it'll make getting your AE comps into PPro a breeze. Learning curves are the name of the game here...
                              • 12. Re: Moving tracks up and down...?
                                the_wine_snob Level 9
                                This can easily be accomplished in two ways:
                                1.) Permanent way - move the Video to a new Video Track at the "bottom" of the Video Track Pane and put the Video onto it. Do the same for the Audio, creating and populating a new Audio Track at the "top" of the stack. They will appear "next" to each other across the division of the two Panes.
                                2.) For editing, without new Audio, or Video Tracks - the two Panes of the Timeline's Audio and Video Tracks can be independently scrolled. Set up each Pane, so that the Video appears at the very "bottom" of your Pane view, scrolling as is needed. Do the same for the Audio Tracks' Pane, again scrolling, as is needed. Now, you will need to adjust the individual Panes to sut, but that takes mere seconds to do - then scroll as needed.
                                • 13. Re: Moving tracks up and down...?
                                  Karel Bata Level 1
                                  This has turned into a bigger debate than I intended - and thanks for the replies! It's just something that crops up occasionally.
                                  There's a lot of other esoteric things that Premiere can do, and one might also be tempted to say "Who'd ever want that?" But somebody somewhere does. I've done a lot of sound editing, so when I'm on an NLE I automatically look for familiar tools. I'm sure I'm not alone there. I see the argument about the risk of folk accidentally moving tracks, but it could be a 'hidden' feature, like you'd have to hold the shift+ctrl key or something. So you'd really have to want to do it. That's what I thought it might be.
                                  But why are the sound tracks kept immovably separate from the video tracks at the bottom? And moving them up and down - to put them next to their respect videos perhaps - could be very handy. And that functionality could be refined even further...
                                  It's a legacy thing isn't it?
                                  And yes - a solo button would be great! That's something I've found myself looking for too.
                                  Anyway I got my answer. Cheers!
                                  • 14. Re: Moving tracks up and down...?
                                    So much about the layout and functionality of the GUI is based on personal workflow. What you are wanting to do, does crop up fairly often, and mostly from the DAW side of things.
                                    For me, it's not an issue, as I can "move" Tracks to suit my Project, albeit with a bit more work, than just click-dragging. I do it so seldom, that I do not mind. My initial setup is usually what I want, or can be easily tweaked, before I begin populating my Timeline.
                                    As for the separation of Audio and Video - I love it! I have PrE, which groups Audio WITH Video and hate it! I find it far too clunky to use properly and also to visualize.
                                    As working with Video (usually first) and Audio are often considered separate opterations with NLE's, I can easily see the wisdom for the separation. With multi-track Audio, I do not usually care to see the Video part of my Timeline, and just collapse it, to get to my 28 +/- Audio Tracks, as that is what I am then focusing on - no longer the Video, which has already been editied. For me, it's like having two programs in one: a Video editor and then an Audio editor.
                                    You might want to take a look at a screen-cap of PrE 7, as it is arranged more like you want. WARNING: its GUI is far less flexible, than with PrPro. I am only recommending that you look at it, and not try to use it - you'll likely find it horribly limiting.
                                    • 15. Re: Moving tracks up and down...?
                                      Here's a "look" at the Timeline and Track layout in PrE4 (one version back, but pretty much the same as PrE7). Look at the Track arrangement. Is this more what you would like to see?
                                      • 16. Re: Moving tracks up and down...?
                                        Karel Bata Level 1
                                        Not quite. But each track could have a button that toggled video/sound/both...
                                        And a similar 'master' button that allowed you to switch quickly between NLE and DAW.
                                        • 17. Re: Moving tracks up and down...?
                                          That is pretty much what I do with the scrolling views of the Video and Audio Tracks. One little drag, and I am seeing just my Audio. Drag back, and I'm only seeing my Video.
                                          • 18. Re: Moving tracks up and down...?
                                            adumi Level 1
                                            Moving tracks up and down would be (to my opinion and workflow) a great comfort when working in the PR space tight environement.
                                            • 19. Re: Moving tracks up and down...?
                                              Some users, especially if they come from a DAW background agree with you. Strong evidence is in this thread, and plenty of older ones.
                                              Now, I spread out over dual 21" monitors, plus have become accustomed to doing things the PrPro way, so I do not even know if I would use the Click-drag method much, even if initiated in a later upgrade - maybe, but maybe not. [Remember I am one of those "old dogs," that your grandfather told you about, and we know how they take to "new tricks?"]
                                              I'd file a Feature Request (linked up thread), as there might be enough clamor for this, that Adobe would implement it. I do not think it would be THAT hard, but am not a coder, so maybe it is flat impossible at this date. If there was a good time for implementing it, it would have been between Pr 6.5 and PrPro 1.0, because that was a total rewrite.
                                              • 20. Re: Moving tracks up and down...?
                                                For anyone coming upon this thread later, HERE is a similar, and slightly more recent one. Now, there are links to each, from the other.
                                                • 21. Re: Moving tracks up and down...?
                                                  shooternz Level 6
                                                  I assume you found the Solo Button in Premiere    It is there in the Mixer panel.
                                                  • 22. Re: Moving tracks up and down...?
                                                    Craig,
                                                    As I understand the two posters' desires, it is not the isolation of the Audio Tracks, but the physical dragging of ones, already populated up/down the order in the Timeline. I do this by just Adding/Deleteing Video, or Audio Tracks, as PrPro does not allow a Click-drag to move the entire Track into a new order. It's how these Tracks display in the vertical hierarchy in the Timeline, that they wish to alter on the fly.
                                                    However, I could have missed something.
                                                    • 23. Re: Moving tracks up and down...?
                                                      Suntower Level 1
                                                      I feel ya. I want this feature about 100 times a day now.
                                                      I think the people who don't see the need for this feature are older 'get the razor blade' types. No disrespect to them, but they're just so jazzed to not have to physically cut tape they don't understand that the bar has been raised.And my guess is they don't do many music videos.
                                                      It's what I call a 'micro-wave moment'. I never understood what all the fuss was about 'micro-wave ovens'. Until I got one. Now? I couldn't imagine not having one.
                                                      Other video editors -do- offer this feature and yeah -every- DAW does this.
                                                      The reason people want this is because we want to experiment! Duhhhhhhhhhhhh! We don't always 'storyboard'. We don't know what we want until we see it. We want to figure it out in the editing process. We're just moving junk around until -something- looks cool. There's no plan! I'm doing music videos and I wanna be able to instantly try lots of clips at various points in the song to see what looks coolest.
                                                      How this is used in DAWs is for 'comping'... creating a final take of, say, a vocal performance, from several takes. You move the tracks up and down to audition which version of each phrase sounds best because, as with Premiere, the top-most track is the one that 'plays'. That's what I want to do for video... instantly be able to audition which clip looks best at different points.
                                                      So... where does one post a feature request? I got toooooooons of 'em!
                                                      ---JC
                                                      • 24. Re: Moving tracks up and down...?
                                                        In my years, I could probably have used this 3-4 times, though it's easy to see how others might use it much more.
                                                        Now, my stuff is not so "free form," and there is usually a script, even if just in my head, so my experimentation comes with my Effects and my Keyframes. Also, I do not do music videos, though many are edited to music, or the music is edited to them. I'm also a person, who grew up with cutting 1/4" audio tape on a splicing block, before I got my two 4-channel reel-to-reels, so I guess that I'm just happy to not have to do that anymore.
                                                        Each day, I still marvel at the joy and the power of doing work in an NLE. There were too many all-nighters over a Moviola, even the 8-plate unit that I got to work on sometimes. See, I remember when Bins were really "bins," and miles of film was hung from their racks. Oh, what I could have done with an NLE, way back when...
                                                        That Feature Request form is a good thing. I would urge all, who could use this feature, to post a request. Do not know how hard it would be for Adobe to add it, but they never will, unless they know that users could really use it.
                                                        • 25. Re: Moving tracks up and down...?
                                                          Suntower Level 1
                                                          Where is the feature request form?
                                                          ---JC
                                                          • 26. Re: Moving tracks up and down...?
                                                            JC,
                                                            Sorry. I thought that I had posted it upthread. Here is the Feature Request link.
