6 Replies Latest reply on Aug 15, 2009 9:47 AM by JayJhabrix
    Kind of milky layer...
    JayJhabrix Level 3
      Sorry if the topic head is a bit vague but that's what it seems like... Someone sent me an .ai file and here's the problem:
      If you look at the image, the two green buttons have identical colour values of  79, 4. 100, 0 but the lower one has a milky cast. The upper is a bullet. The lower is a filled circle.
      The tiff file below (original) also seems to have some kind of a muted cast...
      The original file was created in AI CS2 Mac. I am using AI CS3 Windows.
      Cheers...
      JJ
        • 1. Re: Kind of milky layer...
          Jacob Bugge MVP & Adobe Community Professional
          Jay,
          Are you sure, the milky one does not have opacity < 100?
          The other one, is that the green square, and is it fading to the right? In that case, it may be an opacity mask with a gradient).
          • 2. Re: Kind of milky layer...
            JayJhabrix Level 3
            Jacob...
            Mmmph... I don't think i like you very much... Your answer was bang on! It was a transparency setting! But why on earth the Art Director would want to set it to 40% i can't imagine!
            Regarding the second problem, the green square is not the issue. It's the image itself... checked opacity there... ok...100%.... but that and other images on other files are looking a bit 'subdued'. However, now that i have a pointer, will have a better starting point to troubleshoot.
            Many thanks Jacob!
            Cheers...
            JJ
            • 3. Re: Kind of milky layer...
              Should I say sorry or welcome, Jay?
              My guess is that the Art Director got carried away somewhere in the process and forgot to deliver consistency.
              I am still pondering over the meaning of subdued in this context. Can you elaborate?
              • 4. Re: Kind of milky layer...
                JayJhabrix Level 3
                Well, it's like the pix have no contrast...  The originals are fine... it's just that, in AI, the imported / linked / embedded image is kind of flat as per the example i posted.
                Edit: Typo of IE replaced by AI
                • 5. Re: Kind of milky layer...
                  Jay,
                  Venturing, not having seen both: Are you sure it is not a question of conversion from RGB (original) to CMYK (Color Mode in Illy)?
                  • 6. Re: Kind of milky layer...
                    JayJhabrix Level 3
                    Actually, have been a bit preoccupied and lazy... will check and revert...
                    Cheers...
                    JJ
