4 Replies Latest reply on Aug 8, 2008 11:51 AM by Peter Grainge
    new projects from old
    Lonno7 Level 1
      Here's the assignment:
      We have a RoboHelp project with about two dozen books (with associated sub-books). Can some or all of these be turned into merged projects?
      Thanx!
      Lon
        • 1. Re: new projects from old
          MergeThis Level 4
          See Peter Grainge's excellent tutorial on merged help.
          Leon
          • 2. Re: new projects from old
            Lonno7 Level 1
            Hi, MergeThis,
            I copied Mr. Grainge's tutorial, but it looks fairly intimidating; what would be wrong with:
            --creating new projects for each book
            --importing existing topics into those books
            --deleting "old" topics once they are safely ensconced in the new projects
            --then merging new projects into the existing "main" project
            Seems like that would be easier and faster...
            Thanx!
            Lon
            • 3. Re: new projects from old
              MergeThis Level 4
              Not that there's anything wrong with that...
              The issue with merged projects that is addressed by Peter's method is "external" links (cross links between projects). The beauty is in having nothing in the master project but a redirect to a child project that actually holds the root level "home page" and any other topics at that level. That way, all "external" links use the path "../otherfolder/externaltopic.htm."
              This relative link will be done automatically, but not at first. As long as you have all the child projects under the \projects folder, your links will at first appear as absolute links (C:\blah_blah). After you close the dialog, then double click the link again, you'll find that RH has assigned a relative path.
              Leon
              • 4. Re: new projects from old
                It looks more intimidating than it is because I have gone into detail.
                Just follow it step by step and you should be OK.
