0 Replies Latest reply on Aug 16, 2009 10:16 PM by 2009-08-17
    this application has failed to start because msvcr71.dll was not found
    2009-08-17
      I just downloaded the Flex 3.3 DK from here:
      http://www.adobe.com/cfusion/entitlement/index.cfm?e=flex3sdk
      Once unzipped I went to run this:
      C:\DATA\My Documents\_jim\flash\open-source\_Software\flex_sdk_3\bin\mxmlc.exe
      When I ran it, I got this error
      This application has failed to start because msvcr71.dll was not found. Re-installing the application may fix this problem
      I searched on Google, and found this:
      http://www.flashdevelop.org/community/viewtopic.php?f=13&t=2932&start=15
      So from there, downloaded "msvcr71.dll", placed here:
      C:\WINDOWS\system32
      And ran the following in the Command prompt: regsvr32 "msvcr71.dll".
      When I did that, I got this error message:
      msvcr71.dll was loaded but the DLLRegisterServer entry point was not found
      The file was not registered
      I saw that the DLL is related to Microsoft Visual Basic Runtime, so I deleted the dll I saved manually, and ran the Microsoft Visual C++ 2008 Redistributable Package (x86) from here:
      http://www.microsoft.com/DOWNLOADS/thankyou.aspx?familyId=9b2da534-3e03-4391-8a4d-074b9f2b c1bf&displayLang=en
      Once done, the dll was not placed in the System32 folder.
      I tried the manual install of the DLL again, but on trying to register it again, got the same error message.
      Has anyone else had this problem?
      Seems like I might have hit a brick wall.
