After generating the chm file, I noticed that some of the numbering font sizes was not the same as the text font size. Some of it appeared correct tho. For example, on one page it would like this:
The numbers are bigger than the text. But on other pages, the the sizes would be the same. What is causing this to happen and how do I fix it?
This is most likely a css issue, check the html of your lists. My guess is that the 'correct' lists have a list class attached, while the 'incorrect' lists do not and use the browser defaults for font-family and font-size.
Please post the html of a correct and an incorrect list.
Greet,
Willam
Greet,
Willam
Thanks for the tip! I manged to edit the .css files and the numberings are now OK.
How did you do that, post the screenshot if available? I am facing the same issue.
@supriyab67236640 This is a thread from over ten years ago so likely the solutions will be different from then. You have already posted your question as a separate discussion, so please see that thread for any responses: https://community.adobe.com/t5/robohelp-discussions/in-html-output-numbering-font-is-changing-to-bro...
