3 Replies Latest reply on Aug 17, 2009 4:46 AM by tony@greenwich
    Trying to retrieve a database sequence number using HTTPService
    tony@greenwich
      I am trying to return a sequence number from a database and assign it to a variable 'recordID'.
      When I call the function getNextRecordID using a button the next sequence number is returned ok.
      The problem is that each subsequent call to this function returns the same number. Only when I close
      and reopen the application does it change.
      Any ideas?
      [Bindable]
      private var recordID:String;
      private function httpResult(event:ResultEvent):void
           recordID = '';
           recordID = event.result.root.sequence.seq;  //sequence.seq is returned from database via xml
      private function getNextRecordID():void
           var getRecordID:HTTPService = new HTTPService();
           getRecordID.url = http://........../getNextSeqNo; //call to oracle database procedure
           getRecordID.addEventListener("result", httpResult);
           getRecordID.send();
