5 Replies Latest reply on Aug 17, 2009 8:53 AM by Gregory Lafrance
    Set border and color for my Datagrid
    3adlouz Level 1
      Hello,
      I woud like to set the border and color of my datagrid. Id o the following but without reseult
      <mx:DataGrid
           xmlns:mx="http://www.adobe.com/2006/mxml"
           sortableColumns="false"
           variableRowHeight="true"
           selectable="true"
           height="85"
           borderStyle="solid"
           borderColor="red"
        • 1. Re: Set border and color for my Datagrid
          Gregory Lafrance Level 6
          It should work, this code works:
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
             <mx:DataGrid borderStyle="solid" borderColor="0xFF0000">
                <mx:ArrayCollection>
                   <mx:Object>
                      <mx:Artist>Pavement</mx:Artist>
                      <mx:Price>11.99</mx:Price>
                      <mx:Album>Slanted and Enchanted</mx:Album>
                   </mx:Object>
                   <mx:Object>
                      <mx:Album>Brighten the Corners</mx:Album>
                   </mx:Object>
                </mx:ArrayCollection>
             </mx:DataGrid>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          • 2. Re: Set border and color for my Datagrid
            3adlouz Level 1
            I really do not know why I have this bas behaviour . My entire code si the following:
            <mx:DataGrid
                selectable="true">
                <mx:Script>
                    <![CDATA[
                        private var _allExpand:Boolean = false;
                        public function get allExpand():Boolean
                            return _allExpand;
                        public function set allExpand(value:Boolean):void
                            _allExpand = value;
                            invalidateList();
                </mx:Script>
                <mx:columns>
                    <mx:DataGridColumn
                        width="320"
                        headerText="Produit"
                        dataField="name"
                        headerRenderer="view.ProductHeaderRenderer"
                        itemRenderer="view.ProductItemRenderer"/>
                    <mx:DataGridColumn
                        width="70"
                        headerText="Doc"
                        headerRenderer="view.DocHeaderRenderer"
                        itemRenderer="view.DocItemRenderer"/>
                </mx:columns>
            </mx:DataGrid>
            • 3. Re: Set border and color for my Datagrid
              In this code you are not setting the border and color, but if you add the code setting them, and remove the renderers, what happens? Maybe that is the problem.
              • 4. Re: Set border and color for my Datagrid
                3adlouz Level 1
                Oooops sorry my code is:
                <mx:DataGrid
                    selectable="true"
                    borderColor="red"
                    borderStyle="solid"
                    <mx:Script>
                        <![CDATA[
                                return _allExpand;
                                _allExpand = value;
                                invalidateList();
                    </mx:Script>
                    <mx:columns>
                        <mx:DataGridColumn
                            width="320"
                            dataField="name"
                        <mx:DataGridColumn
                            width="70"
                            headerText="Doc"
                    </mx:columns>
                </mx:DataGrid>
                • 5. Re: Set border and color for my Datagrid
                  If I reduce it to this, it works, so I would examine your renderers to see if they are causing the problem.
                  Perhaps you need to call super() in the constructor if they are ActionScript classes.
